EPP mode parallel port comms
Results 1 to 10 of 10
    Aug 2010
    Maryland, USA
    Default Re: EPP mode parallel port comms
    I have the comm part pretty well worked out between both PC and PIC. But now I have 2 more questions. First is really a yes or no kind of thing, Anyone know of a bootloader to be used with a parallel port? Even better if linux based.
    Now to the harder, but much more conceptual question. I want to make my I/O card somewhat user configurable. At first I am just thinking about the user declaring pins as inputs or outputs. that leads me to the hardware side of how to have it be either. ie, I don't think I want a pull up on an output. Now on the software side I think that is not too hard, basically the user will be setting the TRIS using a GUI. then the correct variables get assigned and volia!
    But now lets say they want to have a PWM output on 1 or 2 or eveb 4 of the pins. Any ideas how to code for that? I am not looking for actual code here, I am just stuck as to how to approach this.
    -Bert
    Maybe have the PC write to an EEPROM. Then at Pic boot time the EEPROM is read for a set of pre difined parameters ....
    Aug 2010
    Maryland, USA
    Thanks Dave, but thats where my brain gets foggy. For instance I can see how I would put a timer value in the EEPROM, then read it at boot time. But what if the user doesn't want to use the timer at all? Do I have an IF NoTimer then skip the timer section? And then would this get checked every time through the loop? that seems like the wrong way to implement it. But I can't think how to do it.
    -Bert
    I think this is something like you want. It is quick and dirty with ON INT
    '  18F6680  24FC1025
    '<FL_PIC18F6680>'
        DEFINE OSC 20
        @ __CONFIG    _CONFIG1H, _OSC_HS_1H
        @ __CONFIG    _CONFIG2H, _WDT_OFF_2H & _WDTPS_128_2H
        @ __CONFIG    _CONFIG4L, _LVP_OFF_4L
        DEFINE LCD_DREG     PORTG
        DEFINE LCD_DBIT     0
        DEFINE LCD_RSREG    PORTE
        DEFINE LCD_RSBIT    0
        DEFINE LCD_EREG     PORTE
        DEFINE LCD_EBIT     1
        DEFINE LCD_BITS     4
        DEFINE LCD_LINES    4
        DEFINE LCD_COMMANDUS    3000
        DEFINE LCD_DATAUS   150
        PAUSE 1000
        DPIN    VAR PORTB.2    'I2C DATA PIN
        CPIN    VAR PORTB.1    'I2C CLOCK PIN
        ADDR    VAR WORD
        DATI    VAR BYTE[45]
        DATO    VAR WORD
        BOOT:
        LCDOUT $FE,1,"BOOTING"
        ADDR = 1
        'FOR TESTING DO A WRITE/READ TO THE EEPROM
        'CHANGE THE VALUE IN I2CWRITE TO TURN THE
        'TIMER ON OR OFF... THE SAME CAN BE DONE
        'FOR T0CON FOR DIFFERENT PWM
        I2CWRITE DPIN,CPIN,$A0,ADDR,[1]
        PAUSE 100
        I2CREAD DPIN,CPIN,$A0,ADDR,[INT_VAR]
        PAUSE 100
        INT_VAR VAR BYTE
        INTCON.5 = INT_VAR    'ENABLE/DISABLE TMR0
        T0CON = %10000000
        ON INTERRUPT GOTO TLOOP
        MAIN:
        LCDOUT $FE,1,"RUNNING"
        PAUSE 100
        GOTO MAIN
        DISABLE
        TLOOP:
        INTCON.2=0:TOGGLE PORTG.4
        RESUME: ENABLE
    Aug 2010
    Maryland, USA
    Thanks Dave, starting to have the fog clear a little now.
    -Bert
