portA.0 cannot be set
Results 1 to 7 of 7
    Nov 2007
    Default portA.0 cannot be set
    Dear Friends,
    I am experiencing a very frustating situation and I am hoping someone can help me solve this problem.
    I have been using Pics for almost 10 years, now, but this problem baffles me. I am using a pic18F8722, and I cannot set porta.o using the following statement: porta.0=1 or porta.0=0. In either cases, it remains high. The tris setting configures it as an output (trisa=0), and all other bits on the port work fine (excluding a.4 of course, which is open-collector).
    However, I can set the pin by using HIGH porta.0 or LOW porta.0.
    I have been trying to figure out the reason behind this for 3 days now, but I give up. I have found a work around by using select case in the following way:
    dummy= state of the pin I want to set
    select case dummy
    case 0
    low porta.0
    case 1
    high porta.0
    end select
    It works, but it is not very elegant...
    even this small program does not work:
    trisa=0
    porta.0=0
    porta.1=0
    pause 10
    porta.0=1
    porta.1=1
    pause 10
    when I check the pins with my scope, I see a nice square wave on porta.1, but port a.0 stays high.
    If I change the program to:
    trisa=0
    low porta.0
    porta.1=0
    pause 10
    high porta.0
    porta.1=1
    pause 10
    Then I see a square wave on both pins.
    My question is: what is the difference between the code generated with
    porta.0=1
    and
    high porta.0
    why is one expression working and not the other one?
    (by the way, yes, the fuses are properly set, ADCON1=%00000111 to set the outputs as digital, A/D module disabled, etc...)
    I appreciate your help.
    Best regards,
    Patrice
    Default Re: portA.0 cannot be set
    Do you have the pins connected to anything? It smells like the good old Read-Modify-Write problem...
    What if you try:
    trisa=0
       porta.0=0
       Pause 1    'Allow PortA.0 to settle low.
       porta.1=0
       pause 10
       porta.0=1  'Allow PortA.0 to settle high
       Pause 1
       porta.1=1
       pause 10
    HIGH and LOW also resets the corresponding bit in the TRIS register (making the pin output) for you so even if you have the pin setup as an input doing HIGH PortX.x will switch it to an ouptut and set it high. I'm not sure WHY it matters in THIS case but we can figure that out IF it turns out to BE a RMW-problem.
    You will need to turn the ADC off.
    ADCON1 = 15
    Nov 2007
    Henrik,
    It was a read-write-modify issue.
    a simple PAUSEUS 1 between instructions solved it.
    Thanks!
    Bonjour Patrice,
    Or simply Write " HIGH or LOW PortA.0 " ... it will automatically add a little time ... ( equal to TRISA.0 = 0 ... )
    hé,hé ... soyons flemmards !!!
    Nov 2007
    Bonjour Alain,
    You are right, I had noticed that writing "high" or "Low" indeed worked as well.
    This is the first time I design a project running at 40 Mhz, so I am dealing with new issues I have not seen before.
    You learn every day!
    A+
    Pat
    Salut Patrice,
    With PIC18, there's LAT port made to avoid this problem
    You write to LAT ... but read from PORT
    LATA.0=1
    LATA.1=1
    LATA.2=1
    LATA.3=1
