Holtek Decoder
Results 1 to 17 of 17
Thread: Holtek Decoder
    New Zealand
    Default Holtek Decoder
    I'm wondering if anyone has a subroutine to decode a Holtek chip - I've spent a couple of hours on it and am more confused now than when I started!!! I've done a search on here and found several people saying that a pic can easily take place of a holtek decoder chip - but in my brain - not so easy.
    I have a LINX ready made transmitter with 8 buttons and a 10 bit address, from what I can figure out it does this:
    sync bits: 01010
    address bits (if set to 1111100000):11111111110101010101
    data bits (button 6 pressed): 0101010101000101
    a zero is represented as 00
    a one is represented as 11
    and open circuit (button not pressed or address switch open) as 01
    where a 0 is a 380uS pulse and a 1 is a 760uS pulse, i was trying to do it with pulsin to determine pulsewidth and convert it, I was going to try and bring it in as serial data and play with it then - but it figured out to me to be 770bps - given that I'd get 20 data pulses (for the address) in 26ms and PBP doesn't allow that as a valid speed.
    The encoding chip is a holtek HT640 (apparently it's the same protocol as motorola use)
    Any help would be greatly appreciated - cheers
    This might help
    http://www.holtek.com.tw/english/tec...df/ha0040e.pdf
    Or this
    http://www.picbasic.co.uk/forum/showthread.php?t=6436
    With the help I received from the above thread, PIC to PIC and no wires!! Also has more capability as it is not limited to 8 or 10 signals.
    If you want, I can post the good code when I get back to the shop(can not do it from memory)
    New Zealand
    I've done pic to pic with no wires - I'm wanting holtek to pic with no wires - the remote I've bought has a holtek chip in it so need to decode that - do you have code for a holtek? If so I'd love to see it
    Cheers
    Dec 2005
    There are far, far too many variables.
    There are several different Holtek chips and the chip frequency (and thus the pulse/space duration) depends on the value of the resistor used for the oscillator. Some use a two state code, others use a three state code. You need to study the Holtek datasheets for the specific encoder and decoder chips you are using.
    Does wireless mean IR or RF? If RF, ASK or FSK?
    Quote Originally Posted by George View Post
    Cheers
    Sorry, no code for the holteks.
    In your case just buy the correct decoder.
    Dec 2005
    I've attached a GIF showing the output waveform from the HT640 sending all ONES, all ZEROS, all ELSE, and repeating those three in ONE, ZERO, ELSE order.
    First, you have to pick the start sequence out of the air (usually signals are sent 3-5 times with the first few setting the receiver AGC) and then capture and decipher the following bitstream. You might do this using the CCP hardware in Capture mode, resetting the polarity after each interrupt but it's not a simple task.
    As you can see there are two different pulse widths and two different space widths. The actual widths will depend on the transmitter oscillator frequency.
    The best advice is to use the Holtek decoder chip with the same oscillator frequency as used by the transmitter.
    The attached code example will decode the Holtek HT640.
    Download the Linx .PDF below for details of the 640 data
    structure.
    http://www.linxtechnologies.com/Docu...datastruct.pdf
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    New Zealand
    Hey thanks Bruce exactly what I was looking for
    Hey George,
    You're most welcome. It's pretty old, but it's simple & it works.
    You can improve the synch bit check part by replacing it with this;
    IF PBIT[0] <= PBIT[1] THEN Begin
    IF PBIT[1] >= PBIT[2] THEN Begin
    IF PBIT[2] <= PBIT[3] THEN Begin
    And you can remove this part; IF Loops > 2 THEN Begin
    I stripped a lot of code out before posting it, but missed that line. It's bits &
    peices of a much larger program that was a first go at decoding the Linx
    hand-held.
    -Bruce
    tech at rentron.com
    Jul 2009
    Having spent a couple of hours decoding the output from a Holtek HT600 encoder (in a Micromark wireless burglar alarm system), using the voltage divider / sound card / audacity method, I decided to post the specs to save anybody else the trouble...
    01 01 0 - 5 bit header
    01 01 01 01 01 - A0 A1 A2 A3 A4
    01 01 01 01 01 - A5 A6 A7 A8 A9 (note A5 doesn't exist and is always 01)
    01 01 01 01 01 - NA AD11 AD12 AD13 AD14
    01 01 01 - AD15 NA NA
    As noted, there is no A5 pin on the chip - this results in 01 always being present in this field. I'm not sure what the final four bits do, they always seem to be 01.
    Hope this helps. I'm hoping Bruce's code will decode this - otherwise I've got the info to write my own :-)
    Jul 2009
    The pulse train looks like this:
    0 (pin pulled low) is encoded as 00
    1 (pin pulled high) is encoded as 11
    - (pin left floating) is encoded as 01
    A[0-9] is the address pin (these are connected to DIP switches on my alarm), AD[11-15] are the data pins - these are connected to other switches corresponding to the data that should be sent. As noted, there is no A5 pin on the chip - this results in 01 always being present in this field. I'm not sure what the final four bits do, they always seem to be 0, 1, 0, 1.
    Between A9 and AD11 there appears to be two sync bits. These appear to be always 01.
    Sep 2008
    Maine, USA
    Default Most excellent code!
    Bruce,
    Just wanted to thank you for posting that Holtek Decoder code. Really nice job and extremely well documented. I had a job up and running using the Linx CMD-KEY keyfob transmitter in minutes thanks to you. Much appreciated.
    Guy
    structure.
    "Do or do not, there is no try" Yoda
    Hi Guy,
    You're very welcome, and thank you too. I'm glad you found a good use for it.
    Edit: If you ever need to create your own PIC chip to emulate the Holtek 8-bit encoder too, I posted a pretty cool project for the Crownhill Amicus board here http://www.myamicus.co.uk/content.ph...Remote-Control with code for one.
    And PC software to control the PIC, so you have a PC-based encoder to control your PIC-based decoder. Pretty fun stuff...
    Last edited by Bruce; - 6th August 2010 at 22:50. Reason: Emulate the Holtek 8-bit encoder too
    -Bruce
    tech at rentron.com
    Jun 2011
    Default Re: Holtek Decoder
    the code work great.
    i there i am newbie in this forum and also at Picbasic pro, i need help in this code as well. the other PIC cannot receive every single bits , pls help
    thanks alot
    CLEAR
    @ device pic16F876A, HS_OSC, wdt_on, lvp_off, protect_off
    DEFINE OSC 20
    ADDRESS VAR WORD ' Holds 10-bit address
    DAT_OUT VAR BYTE ' Holds 8-bit data byte
    BITS VAR BYTE ' Bit index for address & data bit pointer
    LOOPS VAR BYTE ' Loop var for encode routine
    LEDGreen var PORTC.4
    ' Use this timing for a Holtek HT640 @3V, 390K osc resistor
    LONGB CON 732 ' 732uS for long bit & inter-bit delay
    SHORTB CON 382 ' 382uS for short bit & inter-bit delay
    ' Use this timing for a Holtek HT640 @5V, 390K osc resistor
    'LONGB CON 861 ' 861uS for long bit & inter-bit delay
    'SHORTB CON 431 ' 431uS for short bit & inter-bit delay
    SYMBOL E_OUT = PORTB.5 ' Assign encoder data out (to RF module) pin here
    ' Bank 1 Hardware initialization
    'OPTION_REG = 128 ' Pull-ups = off, GPIO.2 = I/O, prescaler to Timer1
    ' Bank 0 Hardware initialization
    PORTB = 0 ' Data output to RF transmitter idles low
    TRISB=%00000000 ' all outputs
    ' sending A#2#3#64 with MCS terminal turns ON relay #1 at address #2
    ' #3 is sent since the FCTN-RLY4-xxx has the upper 2 address bits of the
    ' 10-bit decoder address left open (floating).
    MAIN:
    ;DEBUGIN 5000,MAIN,[WAIT("A"),ADDRESS.LOWBYTE,ADDRESS.HIGHBYTE,DAT_OUT]
    ADDRESS = $31F '1100011111
    DAT_OUT = $99 '10011001
    ENCODE_640:
    high LEDGreen
    FOR LOOPS = 1 TO 8 ' 8 data packet bursts per transmit period
    ' to simulate user button presses. |
    ' now do synch period & synch bits _ __ _ __ _|
    HIGH E_OUT : PAUSEUS SHORTB ' | | | | | | | | | |
    LOW E_OUT : PAUSEUS SHORTB ' | | | | | | | | | |
    HIGH E_OUT : PAUSEUS LONGB ' | | | | | | | | | |
    LOW E_OUT : PAUSEUS LONGB ' | | | | | | | | | |
    HIGH E_OUT : PAUSEUS SHORTB ' | | | | | | | | | | ADDRESS | DATA
    LOW E_OUT : PAUSEUS SHORTB ' | | | | | | | | | | 10-BIT | 8-BIT
    LOW E_OUT : PAUSEUS LONGB ' 14mS | | | | | | | | | |
    HIGH E_OUT : PAUSEUS SHORTB '_____ | |_| |__| |_| |__| |
    ' SYNCH BITS |
    ' now encode/send address
    FOR BITS = 0 to 9 ' send 10-bit address
    IF ADDRESS.0[BITS] = 1 THEN ' a 1 indicates the address bit is floating. NOT 1
    NEXT BITS
    ' now encode/send data
    FOR BITS = 0 to 7 ' 8-bit data
    IF DAT_OUT.0[BITS] THEN
    NEXT BITS
    LOW E_OUT ' start synch period @ start of 2nd data packet
    PAUSE 14 ' 14mS to 15mS synch period
    NEXT LOOPS ' Close loop
    LOW E_OUT ' Disable transmitter (turn off carrier)
    low LEDGreen
    GOTO Main
    Jun 2011
    Any Help Pls.. i does received the data but not what i set in
    Jun 2006
    Bangalore, India
    Post Re: Holtek Decoder
    Try the HT648L. This will decode data from the HT640.
    Just make sure you select the same address as the one selected on the encoder (HT640)
    Nov 2009
    London
    Just to make sure I am getting it correctly (Bruce's code), is the Frequency of the operation of Holtek 640 in the above example 79Khz (appx) ?
  1. CTCSS Tone Decoder Sample Program
    By sozkarabacak in forum General
    Last Post: - 20th October 2009, 07:15
  2. Req: Basic code for 32 bit hitach ir decoder
    By aa222k in forum mel PIC BASIC Pro
    Last Post: - 6th January 2009, 06:16
  3. tone decoder
    By grounded in forum General
    Last Post: - 30th June 2008, 21:46
  4. Replies: 1
    Last Post: - 10th May 2006, 16:17
  5. 3-to-8 Decoder Program
    By BlackNoir in forum mel PIC BASIC Pro
    Last Post: - 28th December 2005, 20:51
