Interrupt Menu System Example and Help Needed
Results 1 to 9 of 9
    Feb 2005
    Bellevue
    Default Not 'menu creative yet'..
    I agree the hard part is keeping it usable!
    My problem is that this is my first 'LCD Navigation' project with buttons. What I want and what I can do are not in alignment...
    I WANT the program to behave like this:
    Initialize:
    - warm up LCD, etc.
    - Ready interrupt buttons on RB0 and RB1 (menu & select)
    - set counters to zero
    while no buttons are pressed
    - go get data
    - If recordflag=1 then
    gosub recorddata
    - covert data to info
    - show data view on LCD
    If Menu=1: Gosub view1
    If Menu=2: Gosub View2
    If Menu=3: Gosub view3
    Goto main
    If main interrupt menu (B0) is pressed cycle through 3 options:
    - Main Menu View - Explans to press B0 to move to next menu B1 to select
    - pressing B1 here does nothing. Pressing B0 moves to next view
    - Change View (BO/B1)
    - If I press the B1 button while looking at this view, it selects it
    - Select Menu1 - If I press B1, it selects it and returns to main
    - If I press B0, it shows the next menu ->
    - Select Menu2 - If I press B1, it selects it and retunrs to main
    - Select Menu3 - If I press B1, it selects it and retunrs to main
    - Select Exit - If I press B1, it selects it and goes to change view
    - If I press B0, it shows Menu1 ->
    - Start Recording(or stop recording if it is already on) (B0/B1)
    - set recordflag to (on/off) depending on what current state is
    - If I press the B0 button while looking at this view, it moves next view
    - Playback recorded data(B0/B1)
    - takes me to a view that shows a warning that data will be dumped
    - if I press BO/B1 it will cancel this and return to top
    - Exit (go back to where I was)
    - If I press the B0 button while looking at this view, it moves first view
    DURING this menu 'viewing', I want the processor to continue to take data in on the serial port.... If I DON'T click any BO/B1, after a certain amount of time, it should just COME BACK to the last menu# it was on...
    My problem is that I can only seem to trap for B0, then cycle through one menu at a time, and ALWAYS select that one (can't skip it). Pressing B1 is not doing anything, and I am not sure how to turn it on as an interrupt.. (18F2525 supporst multiple INT, and I THOUGHT I turned them on..)
    Any hints?
    Tom
    My suggestion, use the interrupt on PORTB change. Have a look to the datasheet.
    Once you jump to the interrupt routine, check the state of your push-buttons and do the according stuff or set some specific flags and do your stuff in the MAINLOOP.
    Feb 2005
    Bellevue
    OK - Once I am in the interrupt routine I need it to WAIT for a few seconds for the user to either click the BO again (in which case I'd do one thing), or click the B1, in which case I'd do something different.
    My problem is I can't find a way to WAIT... Is it some sort of loop?
    while RB0 <> pressed then do (do main routine stuff - read from port/convert)
    * time out after 5 seconds and return
    If RB1 is pressed then do (something)
    if RB0 is pressed then do (something else)
    wend
    Feb 2005
    Bellevue
    With the 18F2525, there is an INT setting for external interrupts on RB0-2. From the sheet:
    9.6 INTn Pin Interrupts
    External interrupts on the RB0/INT0, RB1/INT1 and
    RB2/INT2 pins are edge-triggered. If the corresponding
    INTEDGx bit in the INTCON2 register is set (= 1), the
    interrupt is triggered by a rising edge; if the bit is clear,
    the trigger is on the falling edge. When a valid edge
    appears on the RBx/INTx pin, the corresponding flag
    bit, INTxF, is set. This interrupt can be disabled by
    clearing the corresponding enable bit, INTxE. Flag bit,
    INTxF, must be cleared in software in the Interrupt
    Service Routine before re-enabling the interrupt.
    All external interrupts (INT0, INT1 and INT2) can wakeup
    the processor from Idle or Sleep modes if bit INTxE
    was set prior to going into those modes. If the Global
    Interrupt Enable bit, GIE, is set, the processor will
    branch to the interrupt vector following wake-up.
    Interrupt priority for INT1 and INT2 is determined by the
    value contained in the interrupt priority bits, INT1IP
    (INTCON3<6>) and INT2IP (INTCON3<7>). There is
    no priority bit associated with INT0. It is always a high
    priority interrupt source.
    I have set (I think) the appropriate bits for B0 and B1 to be interrupts. How can I tell the difference in an interrupt routine tho?? Since I am not watching for B1 to go high.... ????
    Tom
    Feb 2003
    Delaware
    Default Ok more on the pot.
    Tom,
    The value of the pot doesn't really matter as long as its over say 5k. You see you are going to set up a voltage divider across Vcc and ground with the wiper going to the A/D pin. Then I simply read the value of the A/D (0 -1023) and I divide it to give me the number of selections I need. Here is an example. Note the tmr1cnt variable. TMR1 is free running with a 1mS period and tmr1cnt is a variable that is incremented every 1mS. This is compared to mud(menu update) to provide the timing to smoothly update the display. The other timing is provided by the variable "I". It is updated every 1mS if a button is pressed. It is cleared if the button is released. This variable is compared to MBP(menu button press) to debounce the button and ensure that it was held in for a bit.
    read_pot:
    adcin 3, adval3
    y = adval3 / 204
    SETUP_MENU:
    if tmr1cnt > mud then
    tmr1cnt = 0
    gosub read_pot
    x = x + 1
    select case y
    case 0
    lcdout $FE,$C0,"->Reset Counters"
    case 1
    lcdout $FE,$C0,"->Set Rej. Dwell"
    case 2
    lcdout $FE,$C0,"->Set Threshold "
    case 3
    lcdout $FE,$C0,"->Prog. Scanner "
    case 4,5
    lcdout $FE,$C0,"->Exit Setup "
    end select
    if i > MBP then
    select case y
    case 0
    tmr1cnt = 0
    i = 0
    gosub reset_counters
    case 1
    tmr1cnt = 0
    i = 0
    gosub set_dwell
    case 2
    tmr1cnt = 0
    i = 0
    gosub set_thrsh
    case 3
    tmr1cnt = 0
    i = 0
    gosub prog_scan
    case 4,5
    @ BSF 0x06,1 ;SCANNER Off
    gosub SETUP_LCD
    end select
    goto SETUP_MENU
    Hope this helps
    Joe
