Read/write a single bit (MCP23018)
Results 1 to 4 of 4
    Jul 2006
    Surrey, BC, Canada
    Red face Read/write a single bit (MCP23018)
    Hello everybody.
    I’m stack in a simple problem. My application required communication with I/O expander MCP23018.
    I made it work except one thing. I need to read single bit and ignore all others. I need also to write a single bit and leave unchanged others. As command looks like this
    i2cwrite sda,scl,CTRL_EE_W,[GPIOB,%00000011]
    so, how can I change, for example 3 bit, and leave all other bits unchanged ( value of other bits unknown and might change)
    I need also read a single bit and ignore value of others.
    i2cread sda,scl,CTRL_EE_R,[IO_dat]
    Any input welcome!
    Vladimir
    Default Re: Read/write a single bit (MCP23018)
    Bitwise operation & masks
    assuming VarA = %11110000
    If i want to set a single bit, say Bit0, I can do it like
    VarA.0=1
    OR doing it with mask
    VarA = VarA | %00000001
    If you want to clear a bit, says bit 7, then you use
    VarA.7=0
    OR
    VarA = VarA & %01111111
    If I want to READ a single bit, say bit 2, then, I can use
    AnotherVar = VarA.2
    Jul 2006
    Surrey, BC, Canada
    Thank you, Steve.
    It is all I need!!!
    No problem dear Canadian brother
