Which PIC do you use
Results 1 to 10 of 10
    Oct 2009
    Utah, USA
    Default Re: Which PIC do you use
    These are the three PIC's that I keep on hand...
    8pin - 12F683
    14pin - 16F688
    20pin - 16F690
    They are all footprint compatible, are pretty much in the top of their category for the pin count, in terms of memory capacity, ram, eeprom.
    Each jump to a larger package just adds 6 more I/O pins while maintaining similar footprint.
    Dwight
    I haven't done much PIC stuff since awhile, so I haven't follow the most recent news and stuff, but the one I prefered for their built-in feature were PIC12F683, PIC16F690, and PIC16F887... Not sure why I don't have any 18F one in the list... weird ... add PIC18F4431 then.
    Those models above allows you to do lots of stuck but USB. 3 size, many built-in feature, really decent codesize too.
    If you don't have any programmer, I always suggest to grab a PICKIT 2 + Development board package (PICkit™ 2 Debug Express or PICkit™ 2 Starter Kit).
    Sure PICKIT 2 is obsolete now, but cheap and still quite handy and capable of. It's standalone application provide some great features such as Terminal (to test your serial communication without having to use any extra hardware or PC serial port) and a 3 channel logic probe (ok not a really fast one, but still handy).
    For (semi) advanced motor control applications you can't beat the 18F2431/4431. It's the only 10/12/16/18 series PIC with a QEI module and it has a wicked ADC with double S/H, 4 sample buffer and "semi automatic" operation. Add to that the PCPWM module. I'd love to see a new K device with those peripherals, faster, more flash and more RAM - that would be so cool.
    My latest "real" project (16 in, 16 out MODBUS slave) was with a 18F25K22, a real nice 28pin device with two USARTs, 32k of flash and pretty cheap for what you get.
    Mar 2009
    8pin - 12F683
    14pin - 16F688
    20pin - 16F690
    check out the newer versions...
    12f1822 instead of the 12f683
    16f1828 instead of the 16f690
    eg the latter 16f1828 has all the feature set of a 16f690, but for about the same price gets you better/more features (capacitive touch module, more timers, the option to set the +ve & -ve ADC references, faster internal osc, better IOC options, etc etc)
    Jun 2011
    Kwa Dukuza, South Africa
    Thanks for this valuable advice. I like the idea of passing the 16F690 by. I have already bought a rail of the 690 ICs but they,ll get used somewhere, sometime.
    Here in SA, the 16F1828 is just US$0.30 more expensive than the 16F690. Seems a good deal to me!
    Kind regards
    John Bond
    Sep 2005
    Campbell, CA
    For hobbyist use, cost really doesn't matter. I would rather spend $10 more for a chip that has all the functionality that I need than work a week trying to get around the limitations of the part I had chosen.
    Use an 18F part for certain. If you can deal with surface mount, use something like an 18F87K22.
    Charles Linquist
