Reading the port - Little help needed
Results 1 to 5 of 5
    Nov 2009
    London
    Default Reading the port - Little help needed
    I would like to ask if someone can suggest me how should I write the following statement as the current one is not working:
    While PortC=%111011 & %001000
        Serout ToTx,N2400,[66]
    wend
    I want to check if ONLY PortC.2 is pulled low & rest are held high. I want to exclude PortC.3 from being read as it has another function attached to it. It's state (PortC.3) should not be considered. Thanks
    Default Re: Reading the port - Little help needed
    WHILE (PORTC = %11111011) OR (PORTC = %11110011)
              SEROUT ToTx, N2400, [66]
              WEND
    or
    WHILE (PORTC = %11110011 | %00001000)
              WEND
    probably what you wanted to do at first
    Nov 2009
    London
    "| %0000100"
    What does this does mister_e? I read the manual it says there that this "|" is used to set the bit. Please explain how it fits with my requirement. Thanks a lot
    it's all about Bitwise operations.
    | is bitwise OR.
    You said you don't need to monitor bit.3?
    So it could be 0 or 1?
    How about making sure this specific is always 1 then?
