problem with a/d in pic12f675
Results 1 to 13 of 13
    Default Re: problem with a/d in pic12f675
    Couple of things:
    1) One of the comparator inputs is on AN0, turn the comparator off, CMCON=7
    2) Don't mess with the GO/DONE bit (bit 1 in the ADCON0 register) if you're using ADCIN - it'll handle it for you.
    3) The LED will only be on when w0 is 100 and 100 only, might be easy to "set" the value to 100 in a simulator but not in a real circuit. Try IF w0 > 100 instead.
    4) I never never seem to remember when to use left- and when to use right justified, if you're like me try both and see what happends.
    Jun 2011
    iran
    input gpio.0
    output gpio.1
    output gpio.2
    define osc 8
    define adc_clock 3
    include "modedefs.bas"
    ansel=%00000001
    adcon0.7=1
    define adc_bits 10
    w0 var byte
    w1 var word
    w2 var word
    cmcon=7
    start:
    adcin 0,w1
    w2=w1
    for w0=65 to 90
    serout gpio.1,t9600,[254,128]
    serout gpio.1,t9600,[#w1]
    serout gpio.1,t9600,[254,1]
    next w0
    goto start
    thank you very very much men
    i used your tricks(henrik) and used your examples(archangel).
    but it isnt working yet.
    please check my example out.
    can you find an error?
    oh,thank you veryyyyyy much!
    in the software all the critical words are with capital letters,when i copied them they turned to lowercase.
    oh, excuse me if my english speaking is weak!!!
    Quote Originally Posted by samannikzad View Post
    i
    From last up,
    I am sure your English is truly better than my Farsi, and your English needs no apologies, it is good enough.
    As FOR CHANGING TO LOWERCASE, You have been punked by MCS . MCS Automaticaly shows reserved words as UPPERCASE, but they remain lowercase in the code, this forum will show a copy paste in it's raw format, so go back and retype the define statements in ALL UPPERCASE LETTERS like so:
    DEFINE OSC 8
    DEFINE ADC_CLOCK 3
    and report back here with the results. Mister_e asked about the config fuses
    study this post and solve some of your headaches:
    Jun 2011
    iran
    hello,
    i did what you said.
    i wrote t with capslock on, and i set the fuse bits and settings on
    my programmer software(practical) or in the simulating software.
    this is a simple program.but it doesn't work neither
    in simulatin software nor on the breadboard(practical)
    see:
    INPUT GPIO.0
    OUTPUT GPIO.1
    OUTPUT GPIO.2
    DEFINE ADC_CLOCK 3
    INCLUDE "MODEDEFS.BAS"
    ANSEL=%00000001
    ADCON0.7=1
    DEFINE ADC_BITS 10
    W1 VAR WORD
    CMCON=7
    GPIO.1=1
    GPIO.2=0
    PAUSE 1000
    GPIO.1=0
    GPIO.2=1
    PAUSE 1000
    GPIO.1=0
    GPIO.2=0
    START:
    ADCIN 0,W1
    PAUSE 100
    IF W1>500 THEN
    GPIO.1=1
    GPIO.2=0
    PAUSE 100
    GPIO.1=0
    GPIO.2=1
    PAUSE 100
    GOTO START
    but it doesn't work yet.
    there is sth that i should say.
    my microcode studio's version is 2.3.0.0
    and it had no support libraries for 12f675.
    then i downloaded "12f675.bas" and "m12f675.inc" and copied them to the mcs
    folders in my drives(near other inc and bas files).
    is there any problems with this process?
    and i can drive the adc module on 16f877a,but not on 12f675.
    since the library files were present in the software.
    thank you for helping me from the other side of the world!
    thank you
    That is most likely the main problem, you do not have a legal copy. PicBasicPro is not a download.
    Jun 2011
    iran
    oh thank mackrackit
    and i have to find a legal,not a cracked version
    of course it's too hard to find it!
    This is a good place to start
    http://store.melabs.com/prod/software/PBP.html
    You might be able to change the chip you are using and get by with the demo version.
    Jun 2011
    iran
    input gpio.0
    output gpio.1
    output gpio.2
    define osc 8
    define adc_clock 3
    ansel=%00000001
    adcon0.7=1
    define adc_bits 10
    w0 var byte
    w1 var word
    w2 var word
    cmcon=7
    start:
    adcin 0,w1
    w2=w1
    for w0=65 to 90
    next w0
    goto start
    hello
    thank you very very much men.
    i did what you said,but it didn't work.
    please check this example out,it doesn't work neither.
    can you find any errors in it?
    thank you very very much to help me.
    Jun 2011
    iran
    Jun 2011
    iran
    note:
    the lines:
    "w2 var word" and "w1=w2"
    must be ommited and are not needed!
    Have you tried it on real hardware or you really trust a sim?
    Still in your previous example you have your DEFINE in lowercase while they need to be un UPPERCASE.... and where are your configuration fuses?
