problem with a/d in pic12f675
Results 1 to 13 of 13
Threaded View
  1. #2
    Default Re: problem with a/d in pic12f675
    Hi samannikzad, Welcome to the forum. I am not able to troubleshoot your code right now, but I will offer some samples written for the 12F675 using adc. I noticed you do not list your configs. Please refer to the FAQs for how to: Presseting Config fuses in code. The code snippets are fairly well commented Example 1
    ' This program controls a relay by sensing an input voltage and
    ' flashes an led vigorisly for no apparent reason ! It serves me
    ' as a demo for the 12f675 microcontroller using ADC and internal OSC
    @ DEVICE pic12F675, INTRC_OSC_NOCLKOUT
    @ DEVICE pic12F675, WDT_ON
    @ DEVICE pic12F675, PWRT_ON
    @ DEVICE pic12F675, MCLR_OFF
    @ DEVICE pic12F675, BOD_ON
    @ DEVICE pic12F675, CPD_OFF
    @ DEVICE pic12F675, PROTECT_OFF
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 3
    DEFINE ADC_SAMPLEUS 50
    ' * * * * * alias ports * * * * * * *
    AD_0  var GPIO.0
    AD_1  var GPIO.1
    set   VAR GPIO.2
    Relay VAR GPIO.4
    led2  VAR GPIO.5
    ' * * * * * Declare System variables * * * * *
    ledlys   VAR BYTE
    setpt1   VAR WORD
    Counts   VAR BYTE
    adval0   VAR WORD
    adval1   VAR WORD
    i        VAR BYTE
    Relayset VAR BIT
    time     VAR BYTE
    CMCON = 7          'comparators off
    ANSEL = %00110011  'GPIO.0,1 - A/D in ,rest digital
    ADCON0.7 = 1       'right justify for 10 bit
    TRISIO = %00000111 'GPIO.0 = input, rest output
    ' *   *   *   * Initialise variables and ports *   *   *   *   *   *
    Relay    = 0   ' set port GPIO.4 to low status
    ' * * * * * * * set variables to zero value * * * * * * * *
    time     = 0
    ledlys   = 0
    Relayset = 0
    GOSUB Calibrate     ' establishes base line setting
    If set = 1 THEN   ' if port GPIO.2 = 1 then
    i = 1
    FOR i = 1 TO 75   ' counts 7500 ms
    led2 = 1
    PAUSE 50
    led2 = 0
    PAUSE 50
    NEXT i
    IF set = 1 THEN ' Save setpt if GPIO.2 is still high, sets variable
    led2 = 1        ' setpt1 to adval0 value then turns on GPIO.4 (relay)
    GOSUB setpt     ' and sets variable relayset to value of 1, turns off
    PAUSE 5000      ' LED2 and sets time variable to zero
    Relay = 1
    Relayset = 1
    led2 = 0
    time = 0
    ELSE            ' OTHERWISE . . . .
    Relay = 0
    Relayset = 0
    time = 0
    IF (adval0 > setpt1) AND (Relayset = 0) THEN 'turn on
    Relay = 1
    Relayset = 1
    time = 0
    IF (adval0 <= setpt1) AND (Relayset = 1) THEN
    time = time + 1
    IF time = 6 THEN
    Relay = 0
    Relayset = 0
    time = 0
    IF ledlys < 2 THEN
    ledlys = ledlys +1
    IF ledlys => 2 THEN
    IF adval1 < %1111001100 THEN ' low battery
    i = 1
    FOR i = 1 TO 10
    led2 = 1
    PAUSE 250
    led2 = 0
    PAUSE 250
    led2 = 1
    PAUSE 250
    led2 = 0
    PAUSE 250
    NEXT i
    led2 = 1
    pause 15
    led2 = 0
    ledlys = 0
    NAP 7    ' low power mode for 2.304 seconds or 8 WDT periods
    NAP 7    ' Repeat 5 more times for a total sleep of 13.824 Seconds
    NAP 7
    NAP 7
    NAP 7
    NAP 7
    GOTO main
    setpt:
    GOSUB Calibrate
    setpt1 = adval0
    Calibrate:
    adval0 = 0
    ADCIN 0, adval0 'read ad0 mv
    ADCIN 1, adval1 'read ad1 Battery
    One more thing DEFINES MUST BE ALL CAPITAL LETTERS no lowercase
    I do not know what went wrong with these code tags !
