16F777 resetting - at seemingly random times
Results 1 to 10 of 10
    Mar 2011
    cape town, south africa
    Default 16F777 resetting - at seemingly random times
    Interrupts? WDT?
    I've the PIC fading through the spectrum with RGB LED strips connected to the three PWM pins. Yet something keeps resetting the program. The timing of the resets is not consistent - at lease once every 2 mins, sometimes after 30 seconds.
    I've turned off the WDT and disabled all interupts - also set all pins to outputs.. still resetting. Have I perhaps done this incorrectly, or missed something?
    Any other ideas what could cause this?
    @ DEVICE PIC16F777, INTRC_OSC_NOCLKOUT, WDT_OFF
    DEFINE  OSC 8
    OSCCON = %01110010 'see data sheet for INTRC speed setting
    ADCON1 = 15	 ' All I/O pins digital
    INTCON.7 = 0 ' tunr off all interuppts
    TRISA = %00000000
    TRISB = %00000000
    TRISC = %00000000
    TRISD = %00000000
    TRISE = %00000000
    ' Set CCPx pins to outputs
    TRISC.2=0 ' CCP1 output
    TRISC.1=0 ' CCP2 output (could also be assigned to RB3)
    TRISB.5=0 ' CCP3 output
    ' Set CCP modules to PWM mode
    CCP1CON = %00001100 ' Mode select = PWM
    CCP2CON = %00001100 ' Mode select = PWM
    CCP3CON = %00001100 ' Mode select = PWM
    ' Set period up for 1.22kHz PWM freq
    PR2 = $FF
    pie2.0 = 0
    pie2.1 = 0
    pie1.2 = 0
    ' Set TMR2 up for 1:16 prescale & turn it on
    T2CON = %00000110 ' TMR2 ON 1:16 prescale
    ' Word vars for 10-bit value of each PWM duty cycle
    DutyR VAR WORD ' Channel #1
    DutyG VAR WORD ' #2
    DutyB VAR WORD ' #3
    cyclespeed var byte
    cyclemax var word
    cyclespeed = 10
    cyclemax = 900
    gosub cyclestart 'INTRO SEQUENCE
    main
    ChangeGreenUp:
    Repeat
    DutyG = Dutyg + 1
    gosub colourset
    pause cyclespeed
    until dutyg = cyclemax
    ChangeRedDown:
    Repeat
    Dutyr = Dutyr - 1
    gosub colourset
    pause cyclespeed
    until dutyr = 0
    ChangeBlueUp:
    Repeat
    Dutyb = Dutyb + 1
    gosub colourset
    pause cyclespeed
    until dutyb = cyclemax
    ChangeGreenDown:
    Repeat
    Dutyg = Dutyg - 1
    gosub colourset
    pause cyclespeed
    until dutyg = 0
    ChangeRedUp:
    Repeat
    Dutyr = Dutyr + 1
    gosub colourset
    pause cyclespeed
    until dutyr = cyclemax
    ChangeBlueDown:
    Repeat
    Dutyb = Dutyb - 1
    gosub colourset
    pause cyclespeed
    until dutyb = 0
    colourset:
    CCP1CON.4 = Dutyg.0 ' Setup 10-bit duty cycle as
    CCP1CON.5 = Dutyg.1 ' a 10-bit word
    CCPR1L = Dutyg >> 2
    CCP2CON.4 = DutyR.0
    CCP2CON.5 = DutyR.1
    CCPR2L = Dutyr >> 2
    CCP3CON.4 = Dutyb.0
    CCP3CON.5 = Dutyb.1
    CCPR3L = Dutyb >> 2
    cyclestart:
    dutyR = cyclemax
    dutyg = 0
    dutyb = 0
    gosub colourset
    PAUSE 500
    dutyR = 0
    dutyg = cyclemax
    dutyb = 0
    gosub colourset
    PAUSE 500
    dutyR = 0
    dutyg = 0
    dutyb = cyclemax
    gosub colourset
    PAUSE 500
    dutyR = cyclemax
    dutyg = 0
    dutyb = 0
    gosub colourset
    Many Thanks!
    Mar 2006
    China
    Default Re: 16F777 resetting - at seemingly random times
    Are you sure you habe a strong and noice free powersupply. Do you power the LED and the PIC from the same supply? Maybe there is not just enough power when you have all 3 LEDs on at maxpower to make white.
    Is BOR turned off or at least set to its lowest setting?
    Are the LED drivven inside their performance (current limiting resistors)?
    Mar 2011
    I have tried three power supplies - Using one for circuit and one for LEDS, and also using the same supply split with a voltage regulator for the PIC circuit. The LED supply is a hefty (and expense!) 12v 8.5 amp supply that should be more than adequate to power 10meters of 5050 smd RGB leds;
    36watts per 5 meters - From Manufacturer
    Thus 10m = 72 watts
    72 / 12v = 6 amp.
    I believe that calculation is correct. No smoke yet anyway...
    On your suggestion, I have set PCON.2=0 (BOR = OFF) and the problem persists.
    Any other ideas? I read something about PCL tables...
    Many Thanks!
    The LED strips have their own resistors. As I am cycling through the colours - there are only ever two colours on at the same time (interesting spectral information!).
    Mar 2011
    here is the circuit;
    Nov 2007
    West Covina, CA
    1. Try adding 1.0uF caps to the input and output of the 5V regulator as well.
    2. I would make sure the 4.7K pullup on the MCLR line has a solid connection. A MCLR left floating would also cause intermittent resets.
    3. Or just disable the MCLR function (MCLR_OFF, if I remember correctly) just to be sure some unseen noise spikes are not triggering the uC reset.
    Louie
    Jun 2006
    Bangalore, India
    Try 47ohm resistor between PWM pins and mosfet gate
