get a sensor digital input to work on a pickit 2 16f690 lpc
Results 1 to 16 of 16
    Jun 2011
    Default Re: get a sensor digital input to work on a pickit 2 16f690 lpc
    Also with the digital sensor program, the light turns on when the state changes, but won't shut off unless i push the button on the lpc. Why? Thanks again. This is the code:
    '-------------------------------< Blinky LED >------------------------------------
    ' File name : BlinkyLed.bas
    ' Version : 1.0
    ' Company : Mister E
    ' Programmer : Steve Monfette
    ' Date : June 22, 2011
    ' Device : PIC16F690
    '---------------------------< Project description >-------------------------------
    ' Beginner code example to blink a Led on PORTc.0 using:
    ' 1) PBPDEMO version
    ' 2) MicroCode Studio
    ' 3) PICKIT 2 Programmer
    '----------------------------< Hardware listing >---------------------------------
    ' - Microchip Low Pin Count Demo Board
    ' - PIC16F690 installed
    ' - *** All jumper have to be installed ***
    ' - Target board will be powered by the PICKIT 2
    ' Pic Configuration
    ' All PIC configuration fuses (Configuration bits) are listed in the
    ' C:\PBPDEMO\p16f690.inc file. Also see datasheet section 14.1
    ' _INTRC_OSC_NOCLKOUT: Using Internal Oscillator
    ' _WDT_ON: Enable Watch Dog Timer
    ' _MCLRE_ON: Enable MCLR
    ' _CP_OFF: Disable Code Protection
    ' _CPD_OFF: Disable Data Code Protection
    ' _FCMEN_OFF: Disable Fail Safe Clock Monitor
    ' _IESO_OFF: Disable Internal/External switchover
    ' _BOR_ON: Enable Brown out detect
    ' _PWRTE_ON: Enable Power up Timer
    OSCCON = %01110000 ' datasheet section 3
    ' -x-------- n/a
    ' --111----- IRCF<2:0> Internal Oscillator Frequency Select Bits (8MHz)
    ' -----xxxx- Read Only
    DEFINE OSC 8 ' tells PBP we use a 8 MHZ clock
    ' Hardware assignment
    ' Here we assign Aliases to PORT pin
    ' this makes the code easier to read
    ' I'll use the Aliases name as written on the schematic
    ' LEDs
    DS1 VAR PORTC.0
    DS2 VAR PORTC.1
    DS3 VAR PORTC.2
    DS8 VAR PORTC.7
    ' Hardware configuration
    ' I/Os (Datasheet section 4.0 & above)
    TRISA = 0 ' All PORTA I/O set as Output (When capable of)
    TRISB = 0 ' All PORTB I/O set as Output
    TRISC = 0 ' All PORTC I/O set as Output
    ' ADCs (datasheet section 9)
    ANSEL = %00000000 ' Set all pins digital
    ANSELH = %00000000
    WPUA = %00000011 ' Enable pullups for buttons
    WPUB = %00000000
    ' Comparator (datasheet section 8)
    ' At Power On, the comparator are already disabled
    ' but let's play safe.
    CM1CON0 = 0 ' Disable comparator 1
    CM2CON0 = 0 ' Disable comparator 2
    ' Software/Hardware initialisation
    PORTA = 0 ' clear PORTA output pins (0v)
    PORTB = 0 ' clear PORTB output pins (0v)
    PORTC = 0 ' clear PORTC output pins (0v)
    WHILE !OSCCON.2 : Wend ' Wait untill the internal OSC get stable
    i Var Byte
    '------------------------------< Main program >-----------------------------------
    START:
    iF (PORTC.7= 1) THEN
    PORTC.0 = 1
    ELSEIF (PORTC.7 != 1) THEN
    PORTC.0= 0
    PAUSE 1000
    PORTC.0=0
    GOTO Start
    Oct 2009
    Utah, USA
    Hey Jason... Looks like you are making progress. At least you are getting LED's to blink, instead of fighting with compilers.
    I have not tried your example program above, but you might try reversing the order of your "IF" statements.
    your code:
    START:
    PORTC.0 = 1
    PORTC.0= 0
    PAUSE 1000
    PORTC.0=0
    GOTO Start
    With the IF statements reversed:
    START:
    IF PORTC.7 = 0 THEN
    PORTC.0= 0
    ELSEIF PORTC.7= 1 THEN
    PORTC.0 = 1
    PAUSE 1000
    PORTC.0=0
    GOTO Start
    How about this...
    Start:
    PortC.0=PortC.7
    Pause 1000
    goto Start
    If you are useing the LPC demo board the push button is tied to MCLR which is resetting your PIC each time you push it, thus causing the LED to go off because you set portC =0 in your program.
    In order to do something similar with an analog sensor you would configure the pin as an analog input instead of digital... I will try and dig up a simple analog example and post it.
    One good tool that I find helpful would be to search on 16F690 and just look at various examples and try to see what others have done. Also look through various code examples in the "WIKI" section at the top of the forum. You might also look over on the MELabs web site, where they have several code examples for various PIC functions.
    PS. instead of using the Quote function to display code in your posts... Move over to the next icon "#" which is used to post code examples.
    Dwight
    OK Jasonstew,
    Here is a code that makes "cylon" eye pattern, and speed will be controled by the rheostat on your board.
    @MyConfig = _INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_ON
    @MyConfig = MyConfig & _MCLRE_OFF & _BOR_OFF
    @ __config  MyConfig
    DEFINE ADC_BITS 8
    DEFINE  ADC_CLOCK 1
    DEFINE ADC_SAMPLEUS 50
    PortA = 1
    PortB = 0
    PortC = 0
    TRISA = 1
    TRISB =%01010000
    TRISC = %00000000
    i var word 'locks up @ 255 with byte
    ANSEL = 1
    ANSELH = 0
    CM1CON0 = 0
    CM2CON0 = 0
    Backlight Var word
    ADCIN 0,BACKLIGHT
    for i = 1 to 255
    portC = i
    i=i  << 1 - 1
    pause backlight
    next i
    for i = 255 to 1 step -1
    i=i >> 1 + 1
    portc = i
    pause 25
    next i
    Do not make too much over the variable names, I recycled some code in this.
    Quote Originally Posted by Jasonstew View Post
    In your code, your TRISC line is not right, you must set some inputs there.... as it is right now, there's only OUTPUT. Change it to
          '  76543210
    TRISC = %10000000
          ' -1-------- PORTB.7 = INPUT
          ' --0000000- PORTB<6:0> = OUTPUT
    And then your main loop may looks like...
    Start:
            IF PORTC.7 = 1 THEN
                    PORTC.0 = 1
                            PORTC.0 = 0
            PAUSE 1000
            GOTO Start
    OR.. WAY easier
    Start:
            PORTC.0 = PORTC.7
            PAUSE 1000
            GOTO Start
    In your code, you enable the Pull up on PORTA, there's no internal pull-up available for PORTC, so I hope you have one
    Jun 2011
    mi pickit2 constantly gets busy after around 15 seconds and i am forced to recompile why?
    That's because of your code in line 11.
    Just kidding, how could we possibly know what the problem might be from what you wrote? So now I am going to sound like a teacher and ask for at least a sentence for each of these topics. (Nah, a teacher would have asked for a paragraph on each)
    1. Gets busy? Busy doing what?
    2. 15 seconds after what?
    2. Recompile, what is forcing you to do this, and why?
    3. What are you doing to get here?
    4. Any errors?
    5. Any code?
    6. Are you using the PICKIT 2 Standalone application, or the command line? If so, make sure you don't run 2 instances (or more) of the application.
    7. What if you change TRISA to...
    TRISA = 255
    Jun 2011
    The problem was solved whjen i changed the code to portc.0 = portc.7. Thanks.
