[Beginner Tutorial] How to get started with PICBASIC PRO Demo, MPLAB & PICKIT 2
Results 1 to 14 of 14
    Default Re: [Beginner Tutorial] How to get started with PICBASIC PRO Demo, MPLAB & PICKIT 2
    I copied the code to the program file and still got syntax errors.
    __config _HS_OSC & _WDT_ON & _MCLRE_ON & _LVP_OFF & _CP_OFF
    I am using MicroCode Studio Pro to complile the program and PICKIT2 for programming.
    Quote Originally Posted by citationjet100 View Post
    . . . and no mention of which version of PBP . . .
    Hi Dave,
    The configs you are using are only for version 3.xx and later versions to come.
    If you are using any earlier version this thread has everything you need to know: http://www.picbasic.co.uk/forum/showthread.php?t=543
    ver 3.xx Make sure you have some spaces just before __config as Assembly is fussy that wayName:  config.png
