Beginner- blinking led's on pickit 2 starter kit
Results 1 to 24 of 24
    Jun 2011
    Default Re: Beginner- blinking led's on pickit 2 starter kit
    the @ device pic16F690, intrc_osc_noclkout, BOD_OFF, PWRT_OFF, wdt_off, mclr_off,protect_off
    command and the pic16F690 opcode error
    Here is some info on how to set your configuration fuses. http://www.picbasic.co.uk/forum/cont...o-your-Program They are case sensitive, so changing them all to capitals will help. Here is one way to do it, if you wanted it in your code space.
    @ __CONFIG _INTRC_OSC_NOCLKOUT & _BOD_OFF & _PWRTE_OFF & _WDT_OFF & _MCLRE_OFF & _CP_OFF
    You may notice that there is no mclr_off or protect_off options in the P16F690.INC in the MPLAB directory. That is causing some of the errors.
    Jun 2011
    thanks for your help, but now I am getting this error ERROR: Unable to execute mpasmwin.Error[118] C:\TEST.ASM 52 : Overwriting previous address contents (2007)
    any ideas?
    When setting the configs in code space you need to comment out the configs lines in the chip's *.inc file.
    Check this out
    http://www.picbasic.co.uk/forum/showthread.php?t=15062
    I'm working on one for MPLAB.
