Re: Beginner- blinking led's on pickit 2 starter kit
Everything can be done within MPLAB (Code, Programmin etc). You just need to start a new project, select the right toolsuite, and start from there. not sure where you stuck with it.
If PIbasic toolsuite is properly installed you should be able to do everything in a snap
About the configuration fuses, check the one used in the assembler code, and check the FAQ. There's a whole thread explaining how to set them. Within MPLAB, the @ Device line shouldn't work, use MPASM @ _CONFIG, still explained in the FAQ.
Bellow, a compilation of few handy things
http://www.picbasic.co.uk/forum/showthread.php?t=11116
HTH
