I am using the 18F4620 and When I call the file in the pickit2 him of the the following message:
Some configuration words not in Hex.file
Ensure default values above right are acceptable
what should make?
in advance thankful,
vicente
what should make?
vicente
Just as it says,
You have defined all of the available config settings and the ones that you did not define will be set to their default.
To make the message go away use all of the configs, but normally this is not a problem. Just check and see if the defaults are OK.
