IF-THEN what?
Results 1 to 11 of 11
Thread: IF-THEN what?
Threaded View
  1. #9
    SWITZERLAND (french speaking)
    Default WORDs "cost" can make a huge difference
    Ioannis,
    Depending on the PIC used, you might want to be careful in what syntax you are going tu use.
    This first code costs you i.e. 11 WORDs (PIC16F628) and 13 WORDs (PIC16F690)
    w1 var byte
    A  var byte
    B  var byte
    IF w1>A THEN
        IF w1<B THEN
    This second code will cost you 60 WORDs (PIC16F628) and 64 WORDs (PIC16F690)
    w1 var byte
    A  var byte
    B  var byte
    IF w1>A AND w1<B THEN
    Roger
