IF-THEN what?
Results 1 to 11 of 11
Thread: IF-THEN what?
    Default IF-THEN what?
    Well, I am embarrased to have this asked, but maybe my coffee is not strong enough.
    Isn't these two totally equivalent?
    IF w1>A THEN
        IF w1<B THEN
            DO SOMETHING
    IF w1>A AND w1<B THEN DO SOMETHING
    They do not respond as expected. I mean as the second snipet.
    Dec 2005
    Default Re: IF-THEN what?
    Both work here.
    A=5:B=10:w1=7
    If w1>A And w1<B
       Debug "w1>A And w1<B"
    EndIf
    If w1>A
      If w1<B
       EndIf
    EndIf
    I tried it here as well and they both seem to do the same thing... I tried with W1 less than A, bigger than B and within the range, both routines responded in the same way, what are you getting?
    Thanks for the replies. Well, I was testing a code for decoding RF remotes based on the MM53200/UM3750 or HT12 transmission protocol.
    The code with the AND in the IF-THEN statements works fine.
    The other with the nested IF-THENs does not.
    Mystery...
    Me too think that both codes are equivalent.
    It reminds me some weird stuff I already experimented in the past, memory leak or whatsoever, run CCLeaner, and reboot. this should do the trick.
    Out of curiosity, are you using MCSP or MPLAB?
    Thanks Steve. I am using MCSP and Pickit2 with Stand Alone Driver.
    You are right about the weird things. I had some in the past for un-explained reasons.
    Will see.
    OK. I think Steve was right.
    I have this test code on a Dropbox folder in order to work on different PCs. On a freshly boot PC, guess what. Works OK!
    How can a reboot make a program running as expected (or not...) ?
    P.S. Maybe it is a tough one for Darrel
