Re: Quick 4x4 keypad matrix question
I just assembled the same circuit using an 16f88 instead of the 16F877. Using the same circuit and code[plus changes for the 16F88], the program works perfect.
These are the register setting I use on the 16F88.
CMCON = 7 '// PortA = digital I/O
OPTION_REG.7 = 0 '// Enable PORTB pull-ups
ADCON1 = 7
ANSEL=%00000000 '// set all analog pins to digital
ANSEL = 0 '// disable ADC
With the circuit working on the 16F88, I resumed working on the 16F877.
I rebuilt and re-checked the wiring on the 16F877. I also got rid of all the extra LCDOUT and HSEROUT commands, while using only the SEROUT command, just like the Bruce's original example. It still has the weird problem. I just cant seem to pinpoint what is causing the error. Its weird too, because I dont have to be pressing the button fast....it does it even if when I press the button slowly. Every once in a while it will display the number below instead of the actual number. Arghhhhhh!!!! I love this stuff
*Archangel, the "ANSI.INC" was from Darrel Taylors easy ANSI module for PBP.
It is the main reason I wanted to use HSEROUT. The ansi.inc only works with the hardware USART, and not with SEROUT(2).
Thanks for the help, Im not giving up on this.
Sean
"Reality is merely an illusion, albeit a very persistent one." , Albert Einstein
