Pickit2 message unknown
Results 1 to 2 of 2
    Nov 2008
    sao paulo - brasil
    Default Pickit2 message unknown
    I am using the 18F4620 and When I call the file in the pickit2 him of the the following message:
    Some configuration words not in Hex.file
    Ensure default values above right are acceptable
    what should make?
    in advance thankful,
    vicente
    Default Re: Pickit2 message unknown
    Just as it says,
    You have defined all of the available config settings and the ones that you did not define will be set to their default.
    To make the message go away use all of the configs, but normally this is not a problem. Just check and see if the defaults are OK.
