Phase angle differences
Results 1 to 7 of 7
    Feb 2005
    Holmfirth England
    Default Re: Phase angle differences
    I have just done something very similar using DT's interrupt routines. When I get back to work I will post the code.
    Bob...
    May 2011
    Quote Originally Posted by BobEdge View Post
    Bob...
    Bob that would be great look forward to seeing how this can be done.
    cheers
    mark
    Feb 2005
    Holmfirth England
    Hi Fanman,
    Here is a little code that uses an interrupt to start a timer and measure the period of a sine wave. It is written for a PIC18F1220.
    define OSC 20
      'channel 0 analog all others digital
    TRISA = 255
    ADCON0 = %00000001  'Vref = Vss Vdd, turn on A/D
    ADCON1 = %11111110  'Only Channel 0 analog
    ADCON2 = %10001010  'Right justified, 2 TAD, TOSC/32 (for 20MHz)
    INCLUDE "DT_INTS-18.bas"     ' Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas"     ' Include if using PBP interrupts
    badweld     var portb.3
    prim        var portb.0
    prim1       var portb.1
    bren        var portb.2
    thy3        var portb.6
    thy2        var portb.5
    thy1        var portb.4
    input badweld
    input prim
    input bren
    high thy3
    high thy2
    high thy1
    input prim1
    angletime   var word
    temp        var word
    period      var word
    period1     var word
    period2     var word
    period3     var word
    period4     var word
    sixtydeg    var word
    thirtydeg   var word
    multiplier  var word
    decimal1    var word
    decimal2    var word
    adresult    var word
    x           var byte 'for next loop variable
    rot         var bit 'rotation 1 = forward 0 = reverse
    zeroflag    var bit  'flag set to 1 at zero crossing
    pause 1000    'give time for supply to settle
    gosub rotation
    'set up timer
    T0CON = %00000000 '1/2 prescale fosc/4 not running
    TMR0H = 0  ;Clear registers
    TMR0L = 0
    INT_LIST  macro    ;  IntSource,  Label,   Type, ResetFlag?
            INT_Handler    INT0_INT,  _ZERO,   PBP,  yes
    @   INT_ENABLE   INT0_INT     ; enable external (INT) interrupts
    goto cycle
    '-------Interrupt Service Routine------------------
    ZERO:
    @ bcf T0CON,TMR0ON ; Switch off timer
    period.lowbyte = TMR0L  'Record Result
    period.highbyte = TMR0H
    @ clrf TMR0H  ; Reset registers to zero
    @ clrf TMR0L
    @ bsf T0CON,TMR0ON  ;Start timer
    period1 = period2  'Move values up the stack
    period2 = period3
    period3 = period4
    period4 = (period / 5)  'Put new reading at bottom of stack
    period = (period1 + period2 + period3 + period4) / 2  'scale period value in micro seconds
    sixtydeg = period / 6
    thirtydeg = sixtydeg / 2
    multiplier = (period / 4) / 859
    decimal1 = (period / 4) // 859 DIg 0
    decimal2 = (period / 4) // 859 dig 1
    zeroflag = 1    'Set zero crossing flag
    You could do something similar, but you would start 2 timers. One to measure the period of the sinewave, and another to time from the start of the sine wave till your other pulse. Then calculating the phase angle would be quite easy. If you use the "PIC Timer Calculator" this makes using the timers fairly easy.
    I would suggest using the interrupt for timing the period, and starting both timers, and just use PBP to stop the second timer, and do the maths etc.
    The input is a H11L1 opto isolator, resistor, and diode in series across the mains. I am measuring 3 phase at 415 volts, I use 33K 14W resistor. The input goes high roughly 500uS before actual zero crossing, but this can be compensated for in the maths.
    Bob...
    Feb 2005
    Holmfirth England
    By the way here is a link to DT's interrupts page: http://darreltaylor.com/DT_INTS-18/home.html That is for PIC18, PIC16 devices can be found through a link at the top left of the page.
    and here is the pic timer calculator : http://www.mikroe.com/forum/viewtopi...15663&start=15
    Well worth a look, makes using interrupts very easy, and the pic timer calculator opend up a whole new world for me. I was afraid to try either before I found out about these two things.
    Bob
    Mar 2009
    Here's a related thread of mine where I shamelessly display my woeful grasp of' all things pic', but a great group effort at steering me to the required outcome...
    http://www.picbasic.co.uk/forum/arch...p/t-13690.html
