16f690 interupt
Results 1 to 5 of 5
Thread: 16f690 interupt
    Jan 2006
    Slovenia EU
    Default 16f690 interupt
    hello,
    I have program which working perfect on PIC18F242. I wish to changed this program and build to 16F690. I was changed some pins between PIC and now don't working properly. Now couldn't test A/D input but Synchro pulse not triggering interrupt routine to my program. I am not convinced if have ADC channel and other configuration set properly.
    down is attached both program. Please help me and check configuration.
    Samo
    '@ DEVICE PIC18F252, HS_OSC
    define osc 20
    DEFINE ADC_BITS 10 ' ADCIN resolution (Bits)
    DEFINE ADC_CLOCK 3 ' ADC clock source (Fosc/32)
    DEFINE ADC_SAMPLEUS 50 ' ADC sampling time (uSec)
    TRISA=%11111111
    ADCON1=%10000010
    ADCON0=%10000111
    sinh var portb.0
    led var portb.1
    out VAR PORTC.0
    b0 var byte
    b1 var byte
    b2 var byte
    W0 var word
    W1 var word
    maxlim var word
    maxlim1 var word
    maxlim2 var word
    minstart var word
    minstart1 var word
    regulacija var word
    reg1 var word
    reg2 var word
    reg3 var word
    reg4 var word
    eeprom 0,[43]
    eeprom 2,[23]
    eeprom 4,[18]
    clear
    high led
    toggle led
    toggle led
    toggle led
    read 0,b0
    read 2,b1
    read 4,b2
    On Interrupt Goto myint
    INTCON = $90
    loop:
    Goto loop
    Disable
    myint:
    adcin 1,maxlim
    adcin 0,minstart
    adcin 2,regulacija
    reg1= (maxlim2 -minstart1)
    reg2= (reg1*regulacija)
    reg3= div32 1024
    reg4= reg3+minstart1
    minstart1=(minstart*10)/B1
    maxlim1=(maxlim*10)/B2
    maxlim2=1024-maxlim1
    if w0=40 then
    toggle led
    w0=0
    if regulacija>=1022 or regulacija=0 then
    high led
    pauseus (1023-reg4)*b0
    high out
    pause 5
    low out
    w0=w0+1
    INTCON.1 = 0
    Resume
    Enable
    program which not working:
    '@ DEVICE PIC16F690, HS_OSC
    define osc 20
    CM1CON0 = 0
    CM2CON0 = 0
    ANSEL = %00001011
    ANSELH=0
    IOCA.2=1
    ADCON1=%00000000
    ADCON0=%10000001
    sinh var portc.2
    led var porta.2
    out VAR portc.1
    b0 var byte
    b1 var byte
    b2 var byte
    W0 var word
    W1 var word
    maxlim var word
    maxlim1 var word
    maxlim2 var word
    minstart var word
    minstart1 var word
    regulacija var word
    reg1 var word
    reg2 var word
    reg3 var word
    reg4 var word
    eeprom 0,[43]
    eeprom 2,[23]
    eeprom 4,[18]
    clear
    high led
    toggle led
    toggle led
    toggle led
    read 0,b0
    read 2,b1
    read 4,b2
    INTCON = $90
    loop:
    Goto loop
    Disable
    myint:
    adcin 1,maxlim
    adcin 0,minstart
    adcin 2,regulacija
    reg3= div32 1024
    minstart1=(minstart*10)/b1
    maxlim1=(maxlim*10)/b2
    if w0=40 then 'and regulacija>minstart then
    toggle led
    w0=0
    high led
    high out
    pause 5
    low out
    w0=w0+1
    INTCON.1 = 0
    Resume
    Enable
    Oct 2009
    Utah, USA
    Default Re: 16f690 interupt
    Not sure which version of PBP you are using... but "Loop" is a reserved word that should NOT be used as a variable name or program label.
    You should change that to something else like "MainLoop", etc.
    Dwight
    Jan 2006
    Slovenia EU
    I use PBP 2.50C and both program sample compiled without problems. "loop variables" by first program working very good. I was trying with "loop1" and was no changed.
    Seems like you forgot to set TRIS registers in the second code unless I am snowblind.
    Ver 2.6 makes LOOP a reserved word.
    Try INTCON = $88
