ADC not working - I'm a new member
Results 1 to 13 of 13
    Aug 2010
    Maryland, USA
    Default Re: ADC not working - I'm a new member
    I think your problem is here:
    Adcin 2, x ' Read ADC value on AN2 (PORTA.2)
    you are reading the value of AN2, then storing in x
    You should be storing in potval
    And WELCOME to the forum!!
    -Bert
    Jun 2011
    Kwa Dukuza, South Africa
    Sorry, I spotted that after I posted but this is still not working...
    I've added
    ADCON1 = %10000100 ' Set PORTA analog and RIGHT justify result
    ADCON0 = %01000001 ' Configure and turn on A/D Module channel o Fosc 8
    and changed
    Adcin 0, PotVal
    I don't understand registers. I've read the PIC16F690 DATASHEET a couple of times. I seem to handle these issues best using the "Monkey see... monkey do" philosophy when trying to grasp complex problems. (Maybe the Monkey see, monkey do is part of my African heritage )
    Aug 2010
    Maryland, USA
    I don't have my book handy, but if you look at the ADCIN section of the PBP manual, there are several DEFINES you need in order to use the ADCIN command. Also to post code in the cool code box, you need to use tags. Really simple:
    [code[ <----should be the other, but then you won't see the tag
    All your code here
    [/code[ <----Again the second bracket should be } without the shift key.
    Maje sense?
    -Bert
    Jun 2011
    Thanks for your help Bert,
    Bert said "[code[ <----should be the other, but then you won't see the tag
    All your code here
    [/code[ <----Again the second bracket should be } without the shift key."
    Ja dit maak sense, dis cool! (Afrikaans response to Bert's last question - For English, replace "this" for "dit" and "dis")
    I've tried the various DEFINE and REGISTER options but I really don't know what I am doing. Nothing happens. I haven't linked up a UART/USART yet so I can't debug and I am in the dark. Hardware RS232 is my next exercise and I think I'll need to understand REGISTERS for that.
    Kind regards from Kwa Dukuza, lost somewhere in darkest Africa
    John Bond
    Aug 2010
    Maryland, USA
    Well now we need the basic stuff - lol. What pic? what version PBP? MPLAB or MCS? PM or MPASM? Internal osc or external? Some of it we don't need for this problem, but its a good idea to let us know what you are working with.
    What doesn't work? do any led's work? Can you make them blink? Is the value just wrong?
    -Bert
    Mar 2009
    I've just glanced at an old 16f690 program, which was unfeasibly huge so I've hacked it down & hopefully not missed anything during the slimming process...
    DEFINE ADC_BITS  8     ' ADCIN resolution  (Bits)
    DEFINE ADC_CLOCK 1     ' ADC clock source  (Fosc/8)
    DEFINE ADC_SAMPLEUS 11 ' ADC sampling time (uSec)
    ADCON1 = %0100000 ' FOSC/4
    CM1CON0 = 0  'turn the pesky comparators off
    CM1CON1 = 0  'turn the pesky comparators off
    CM2CON0 = 0 'turn the pesky comparators off
    CM2CON1 = 0 'turn the pesky comparators off
    ANSEL       = %0000010        'RA1 (pin 18) AN1 analogue
    PotVal Var Byte
    '********program starts......
    adcin 1, PotVal
    '[do cool stuff with contents of PotVal here, then have a cup of tea & a nap]
    You don't need to worry about ADCON0 (since the ADCIN command selects the ADC channel for you) *unless* you start wanting to use 10 bits, then you need to modify ADCON0.7 to suit (LH or RH Justify)
    Jun 2011
    Thanks Bert and Hank
    No time for tea or a nap but I'm sure this will solve my ADC problem. I now have a problem with the compiler. It crashes after a couple of downloads and only works again after reloading both PBP and MPLAB. I will make a new post on these issues
    Hank - Thanks for that warning on 10 bit (LH or RH Justify) because I will be using 10 bit to measure piezo pressure sensor and I will discarding the upper 1 or 2 bits to reduce the span to 8 bits. I am looking for a 0.05 Bar (peak to peak pressure fluctuation) to determine the speed of an air motor running at between 5 bar and 6 bar. 8 bit, without reducing the span, makes it a bit tight!
    Thanks again and kind regards
    John
