Multiplexing 7-Segment
Results 1 to 6 of 6
    May 2010
    Default Re: Multiplexing 7-Segment
    Common cathode is common negative or ground so by assigning it 0's your making it negative so switching it on
    EDIT: assigning the cathode itself negative which is connected to portb, by assigning the segments (portc) 0's yea that would blank them.
    Ah by clearing portc which is connected to the segments i have solved the problem thanks so much guys
    Feb 2005
    Holmfirth England
    Hi Ross,
    Glad you got it to work. Now you can move on to not displaying any leading zero's.
    Very nice code by the way, much more efficient than what I came up with a few years back.
    Bob...
