How do I rescale an input value-> lower output & avoiding floating point?
Results 1 to 5 of 5
    Mar 2009
    Default Re: How do I rescale an input value-> lower output & avoiding floating point?
    Excellent...I realise this was more a maths question (which you can all now tell I suck at) rather than a PICBAsic one....but that's exactly what I needed, & I shall use it gratuitously :-)
    Don't forget the */ operator.
    Basically */ is like multiplying by 1/256 parts. So x = y */ 256 is the same as x = y * 1 and x = y */ 128 is the same as x = y * 0.5.
    So why is it "better" than manually multiplying and dividing?
    Because the */ operator doesn't actually divide anything (division is slow in software). It multiplies the two values giving a 32bit intermediate result. It then takes the middle 16 bits of that intermediate value and returns those bits as the result. Lets say ADresult = 255
    PWM = ADResult */ 150
    It multiplies ADresult by 150 resulting in the intermediate value of 38250 which in binary form looks like:
    00000000 00000000 10010101 01101010
    It then "extracts" the middle 16 bits of this value and returns those as the result. What's 00000000 10010101 in decimal? Yep, it's 150... or 149 actually.
    Lets say you want to do x = 12345 * 1.45. 1.45*256=371 so
    x = 12345 */ 371
    Behind the scenes you'd first get 12345*371=457814 which, expressed in binary, is:
    00000000 01000101 11100010 10011011
    Those 16 middle bits ( 010000101 11100010 ) in decimal form is 17890 which is pretty close to 12345*1.45.
    It's not perfect but there's usually a way to make it "fit" pretty good - and it avoids using division which, again, is a pretty slow operation on these devices.
    Then we have the ** operator which is the same thing but it performs an inherent division of 65536 instead (ie. it returns the top 16 bits of that 32 bit intermediate result).
    Mar 2009
    Wow.....Henrik, that was a stonking reply....it's now in my test program & works a treat (as did pedja089's formula, but I like the fact that */ is that little bit quicker).
    Many thanks for taking the time to explain....great stuff
