Weird problem with logic level on pin.
Results 1 to 13 of 13
    Default Weird problem with logic level on pin.
    I just had weird problem that I can't really explain, hopefully someone else here can.
    Basically I have an 18F2431 device. One of it's pin is used as an fault-input normally pulled high thru 4.7k and then two active LOW signal are OR'd thru diodes to this pin.
    In my Main loop I had this (basically):
      If Fault_Input = 0 THEN
        Fault_Flag = 1
        GOSUB Abort
      EndIf
      If FaultFlag = 0 THEN
        If RunServo = 1 THEN GOSUB DoServo
      Goto Main
    RunServo is a flag that gets set by a timer interrupt, currently at 1.5kHz.
    This has worked fine for a very long time but a user has a problem where I suspect electrical noice is tripping the fault input. Therefor I thought I'd implement a simple filter and did this:
      If FaultInput = 0 THEN
        Accumumlator = Accumulator + 1
        If Accumulator = Limit THEN
        FaultFlag = 1
        GOSUB Abort
      EndIf
        Accumulator = 0
      EndIf
      If FaultFlag = 0 THEN GOSUB DoServo
    Goto Main
    Again, this is not exactly how it's done but the principle is the same.
    To my surprise this didn't work. Well, it worked when the fault was triggered by one of the two OR'd signals but not by the other. The one that worked has a simple switch to GND making the voltage at the pin one diode drop (~0.6V). But the other input have a transistor (optoisolator output) as its "switch" to GND and there was about 0.55V voltage drop across that for a total "low" voltage at the pin of 1.15V.
    This 1.15V is above the logic low thershold of the input which at Vdd=5V is about 0.75V. I fixed the problem by changing the diode to a schotky type with lower forward voltage drop and it now seems to be OK.
    The big question I can't find the answer to is how and why it has worked before adding the filter code (there's been ano problem at all that I know of...). It doesn't matter if I set Limit to 1 which should make it trip the first time it sees the signal. The only difference with that is that it won't get checked untill the RunServo flag is set which happens 1500 times/second.
    Anyone's got any ideas on what is happening here, it's clear that I was operating outside the electical specs but why does it matter WHERE in the code I actually check the input?
    Thanks guys!
    Default Re: Weird problem with logic level on pin.
    Probably not...
    But what if the flow is changed a bit?
        IF RunServo = 1 THEN  CONTINUE
        CONTINUE:
        IF FaultInput = 0 THEN
            IF Accumulator = Limit THEN
            FaultFlag = 1
            GOSUB Abort
            'ENDIF
            Accumulator = 0
        IF FaultFlag = 0 THEN GOSUB DoServo
        GOTO Main
    Thanks Dave, I see now that I made a terrible mistake when typing in the example, the Accumulator gets reset when RunServo is 0 and not when FaultInput is 1, this is of course wrong. That, however, is not the case in my real system. Here's the exact code, cut and pasted from my program:
    If ServoFault = 1 then Goto OverRunPID          'General fault flag set - don't run servo loop.
    If RunPID then                                  'Time to run the servo-loop?
    '----------------------------- Added 2011-06-03 -----------------------------------
        If ip_Fault_Input = 0 THEN                                  'External fault input is "active"
            FaultFilterAccumulator = FaultFilterAccumulator + 1     'If so we increment the accumulator for the filter
                If FaultFilterAccumulator = FaultFilterConstant THEN  'Have we reached the filter limit?
                    ExternalFault = 1                                 'Set the FAULT Flag
                    BlinkPattern = Pattern_Ext_Fault                  'Change the pattern for the status LED
                    GOSUB AbortServo                                  'Abort the servo loop.
            FaultFilterAccumulator = 0
     op_LED = 1                                    'Drive LED on the module.
     GOSUB DoServo                                  'Rune the servo loop
     RunPid = 0                                     'Clear flag
     op_LED = 0                                    'Turn off LED on the module.
    OverRunPid:
    This works fine now that I've changed the diode so the voltage at the pin is within specs. If I change it back to the 1N4148 it does not work, the input is not seen. But WHY does it see it before, when the checking of the input was outside the IF RunPID THEN construct? Here's how it looked before which has worked fine for years:
        ExternalFault = 1                           'Set software flag indicating fault
        BlinkPattern = Pattern_Ext_Fault            'Select the "blink pattern" for the FW-LED
        GOSUB AbortServo                            'Abort servo operation.
     PortA.0 = 1                                    'Drive LED on the module.
     PortA.0 = 0                                    'Turn off LED on the module.
    OverRunPID:
    If I run this version, with the original diode in place it works just fine and both versions above works now that the voltage level on the pin is within specs. But why does one work and not the other when the voltage is slightly out of spec? I wouldn't be surprised if neither worked but the original code have worked, with the original hardware, "for years".
    The only thing I can think of is that previously the input could get checked tens of thousand of times per second depending on what else was done thru the main loop. Perhaps some capacitive coupling or whatever made the voltage go down to within specs for a short time making the PIC pick it up. But now, when it's "only" checked 1500 times per second that isn't working any more....I don't know...
    Depending upon which port you are using . . . some Schmidt trigger inputs there.
    ...Never mind.....
    As the code shows I'm using PortA.0. Schmidt trigger or not why would that make a difference in this case, care to elaborate a bit? Same pin, same signal, same voltage on input. One program sees the input it, the other doesn't.
    I'm still pretty much stumped on this one.
    By any chance... is there still any ADC or Comparator enabled on those specific pins...
    Aahrgh, sorry can't read my own code...The input pin in question is PortB.3 not PortA.0, sorry about that - and it IS set to an input.
    No, the 18F2431 doesn't have any comparators and all pins are set to digital with ANSEL0 = 0.
    Here's what the hardware looks like (again, that should read PortB.3, not A.0):
    As I've said, the hardware has been this way "for ever" and it has been working just fine "for ever". I changed the code and all of a sudden it didn't see the input. I could go back and forth between working and not working by basically changing where in the code I polled the input.
    Again, the voltage at the pin WAS indeed outside the electrical specs but I still don't understand how it can see the input in one version of the code and not the other. The diode in series with the opto-isolator is NOW a shotky type and it's back up and running with the new code. I'm still looking for an explanation though.
    Hello Henrik,
    Here is my thoughts, for better or worse . . . Schmidt Trigger is more particular as to threshold voltage as to when it switches, both high and low. TTL switches around 1/2 way between VSS - VDD, if your diodes are different in terms of their switching voltage, as I see it, 1 will work and the other will not, and your VOM might not be high enough impedance to see the difference.
    In any event, as I said, those are my thoughts . . .
