Re: Problem in sending command from VB6 to PIC18F458
Did you tried the last code example over there?
http://www.mikroe.com/esupport/index...soft_uart_read
However I would suggest
http://www.mikroe.com/esupport/index...barticleid=157
I would also suggest you to post on MikroElektronika forum, here it's for Melabs PicBasic Pro Compiler
The VB side should work.
