Problem in sending command from VB6 to PIC18F458
Results 1 to 9 of 9
    Jun 2011
    Default Problem in sending command from VB6 to PIC18F458
    hii.. i'm new to VB6 and PIC.. i have problem to send data from VB6 to PIC.. actually my project is to measure current temperature and control on/off valve using zigbee module..
    The problem is when i click command button in VB6, the PIC doesn't receive the signal. I'm not sure on the coding in VB and PIC. Is it correct to send a character in VB6 to PIC? Can PIC receive a character?
    I'm using Zigbee module which transmit data wirelessly from PC to PIC..Is it possible for VB to give command to PIC? i mean wirelessly transmit the command from VB to PIC..
    My VB coding:
    Private Sub Command1_Click()
    MSComm1.Output = ??
    End Sub
    can anyone give example on the coding..plz help me..
    Default Re: Problem in sending command from VB6 to PIC18F458
    Check out this link
    http://rentron.com/VisualBasic.htm
    Frankly... you shouldn't consider VB6 in 2011. VB.NET (2005, 2008, 2010) is by far better.
    Jun 2011
    i never use vb.net before..but if i use the software, is it possible to send command using zigbee (wireless) from PC to PIC..i've tried so many times using vb6 but the PIC seems like not receive the signal..the measured temperature can be displayed on the vb6 program but when i add the click button in vb6 to give command to PIC, my sensor doesn't do the measuring temperature..how to solve this problem?
    OK no problem, VB6 is still workable and if you already know it, then let's try to find your problem.
    What I suggest is to start small, I mean get rid of the ZigBee thing for now and just try to send some data from your PC to your PIC. Once you prove the hardware & software is OK, then add some pleasure to it.
    Couple of things to check:
    Is the Baudrate properly set on both side
    Use a scope and see if there's any signal going from the PC to the PIC
    debug further on that. Try the example on the previous link on RENTRON website.
    We can have a look on your code, just paste it here.. PC and PIC side. Also tell us which PIC you're using and post your schematic. The more info info you give, the best.
    Another cool thing to debug serial communication is called a Serial Port Sniffer. HHD soft one's my favourite.
    http://www.hhdsoftware.com/serial-monitor
    Pretty sure I've already posted something like that here... will try to find it.
    Jun 2011
    Thank you mister_e..
    I've set both baud rate=9600.
    This is my PIC coding:
    unsigned long temp_res;
    unsigned long h;
    void NumtoChar(char a)
    unsigned char digit[3];
    digit[0]=a/100;
    digit[0]+=0x30;
    a=a%100 ;
    digit[1]=a/10;
    digit[1]+=0x30;
    digit[2]=a%10;
    digit[2]+=0x30;
    Soft_UART_Write(digit[0]);
    Soft_UART_Write(digit[1]);
    soft_UART_Write('.');
    Soft_UART_Write(digit[2]);
    void main()
    Soft_UART_Init(PORTC, 7, 6, 9600, 0);
    ADCON1 = 0x81;
    TRISA = 0xFF;
    TRISB = 0X00;
    TRISC = 0X00;
    TRISD = 0X00;
    while(1)
    temp_res = ADC_Read(0) >> 2 ;
    delay_ms(300);
    PORTB = temp_res ;
    h = temp_res*1.3;
    NumtoChar(h);
    ADRESH = 0;
    ADRESL = 0;
    This is my VB coding:
    Option Explicit
    Dim ipt As String
    MSComm1.Output = "M"
    End Sub
    Private Sub Form_Unload(cancel As Integer)
    If MsgBox("Are you sure you want to quit?", _
    vbYesNo + vbQuestion, _
    "Exit") = vbNo Then
    cancel = 1
    Else
    End If
    End Sub
    Private Sub Form_Load()
    MSComm1.CommPort = 3
    MSComm1.PortOpen = True
    End Sub
    Private Sub Timer1_Timer()
    ipt = MSComm1.Input
    ipt = Right(ipt, 4)
    Text1.Text = ipt
    End Sub
    The pic coding works and the temperature measured can be displayed on VB. But the VB coding above i add command button to send a character. I should add in the pic coding too right? I'm not good at coding. When i add receive coding in pic it doesn't works. The vb can receive temperature from pic, meaning they can communicate. Just the problem is the pic can't receive from vb. how to send the command from vb to pic?
    Basically you can use comm port(COM1) to talk to your module but it is also applicable to usb(just need serial to usb convert) here is a link that might help set up to wrte to communication port using VB http://www.bitwisemag.com/copy/vb/vb1.html
    then read input data using picbasic command(see peek and poke, you can search in this forum).
    regards,
    joseph
    I'm sorry, my mistake you can use "serout" to read specific pin to read.
