I've done a layout for DIP-28 but combining the two appears to require multiple layers which adds too much cost. I'm trying to keep these as bare bones as possible to keep the cost down. I'll do a separate DIP-40 version later.
I've finished designing Main boards that are Arduino form-factor and pin-compatible for DIP-24 and DIP-28 as well as one for DIP-40. The latter is pin-compatible except for added pins not present on the Arduino. My interest was to support ZBasic but the DIP-24 version will also support BasicX (BX-24) as well as BasicStamp2.
All use a simple serial interface and require an external SMPS (Switch Mode Power Supply) as I wanted to minimize cost. The DIP-28 & DIP-40 versions include a 64KB SPI EEPROM (ST M95512).
There are ZIP files containing JPGs of the boards on my web site.
DIP-28
The DIP-28 board can be 3V3 or 5V and has a socket for the crystal so it can use 7.3728, 14.7456 or 16MHz crystals. The first two are for 3V3 (ZX-328l) and 5V (ZX-328n). 16MHz is for Arduino - SparkFun sells an ATmega328 with the Arduino bootloader pre-installed.
I have not explored the Amicus18 pin-out but I understand it is not 100% pin-compatible with the Arduino so do not know whether these boards can be used with Amicus18 shields but they might serve as a pattern for anyone wanting a DIP-40 Amicus18. I will release the designs and Gerber files as Public Domain once I've been able to test them (3-4 weeks away).
There are ZIP files with JPGs on my web site - DIP-24 DIP-28 DIP-40
