HSER baudrate
Results 1 to 15 of 15
Thread: HSER baudrate
    Sep 2009
    Default Re: HSER baudrate
    Everything works great. The calculator has really helped me.
    Here's the code if someone needs it.
                 IF HSerBaud=0 THEN
                    RCSTA = 0
                    SPBRG = 207 ' 300 Baud @ 4MHz, 0.0%
                    RCSTA = $90 ' Enable serial port & continuous receive
                    TXSTA = $20 ' Enable transmit, BRGH = 0
                 IF HSerBaud=1 THEN
                    RCSTA = 0
                    SPBRG = 25  ' 2400 Baud @ 4MHz, 0.17%
                 IF HSerBaud=$BD THEN
                    RCSTA = 0
                    SPBRG = 25  ' 9600 Baud @ 4MHz, 0.16%
                    TXSTA = $24 ' Enable transmit, BRGH = 1
    For safety sake, I would set RCSTA at the end, just after TXSTA.
    Sep 2009
    Done. But I don't see what difference it makes.
    Can someone explain?
    It shouldn't make so much difference, but it's a bit more logical to me
    1. You disable the USART
    2. You set the baudrate and mode
    3. You Enable the USART
    Open the datasheet, and see what else you do when you write 0 or $90 to RCSTA, it does more than just enable/disable the USART.
    Sep 2009
    I looked into datasheet, and saw to change a bunch of thing. I just need to reset and set the seventh bit RCSTA to turn off and on UART
    Is there a way to use the parity bit. Suppose 2400.8, E, 1, or 9600.8, E, 1 As I see hardware support and the ninth bit. The PBP I saw that there define the ninth bit.
    If I add this to the beginning of the code
    DEFINE HSER_EVEN 1
    DEFINE HSER_BITS 9
    How will changes in RCSTA, TXSTA,SPBRG registers affect hserin or serout.
    RCSTA, TXSTA, SPBRG will override the DEFINE and configure the PIC USART. It doesn't affect Serout, Serout2 or DEBUG. Those are software solution.
    Again check out the USART section about Parity.
    Sep 2009
    Default parity
    I continue where I left off ...
    This is code:
             define OSC 4
            OSCCON=%01010110
    DEFINE HSER_CLROERR 1 'Hser clear overflow automatically
    '        SPBRG = 25  ' 9600 Baud @ 4MHz, 0.16%
    '        TXSTA = $24 ' Enable transmit, BRGH = 1
    '        RCSTA = $90 ' Enable serial port & continuous receive
    DEFINE HSER_BAUD 9600        'Set Baud rate to 9600bps
    DEFINE HSER_BITS 9        'Set to 9 bit mode
    DEFINE HSER_EVEN 1        'Set Even Parity
    TRISB.7 = 0 'Make Tx output
    TRISB.5 = 1 'Make Rx input
     HSerOut ["Parity:)"]
    Use this or not
    Always get a 9600, N, 1. PIC never send parity bit.
    I'm banging head all day, but I can't catch what I missed.
