Hello,
I'm not very familiar with the hardware serial port. So far I have used define.
But when I tried this:
I got an error, Redefininig symbor that can not be redefined...Code:HSerBaud var byte IF HSerBaud=0 THEN DEFINE HSER_BAUD 300 ENDIF IF HSerBaud=1 THEN DEFINE HSER_BAUD 2400 ENDIF IF HSerBaud=$BD THEN DEFINE HSER_BAUD 9600 ENDIF
I do not know what registers should be set to change the baud rate.
If you can help, so I would not read the whole datasheet. I'm using PIC18LF14K50.
Thanks![]()
