If your hacking an old printer you will likely find the driver already on the build in electronics. I have used parts of existing PCB and installed electronics by cutting the needed traces to the driver ( usually a multi-pin IC mounted to a heatsink) and feeding them with my added circuit. Find the largest ones on the heatsinks and look up the data sheets, and you might just get lucky. should find a 5v source there too.
As for weight, consider some strong line attached to your carriage over a pulley with a counter weight to balance your load. If the movement isn't too fast, a pretty small stepper will move it when balanced.
Bo
