Help please I am so lost just need pointing in the right direction
Results 1 to 23 of 23
    Aug 2010
    Maryland, USA
    Default Re: Help please I am so lost just need pointing in the right direction
    Do you have to do the hardware also? What kind of servo? R/C type or real servo, what size stepper? Do you have to do the stepper drive or just send step/dir signals? What are the outputs? Just set and clear a pin or is something connected to the pin?
    All of the above are great suggestions, but really more information is needed to "point you in the right direction". Is this a job interview or a project for a job? The requirements are a bit strange.
    -Bert
    I will throw my 2 cents in here, first off I agree with Mr E. 100%. I would add this: A JDM programmer can be had on ebay for about 10 bucks US, PBP Demo is free but won't do elaborate program, but will do simple programs, use small cheap pics and use several and use alegro stepper controller chips. You might get someone else to compile your code in the beginning and then load the hex. I stayed away from microcontrollers because of Basic stamps high price ! FOR many years ! There are some cheap / free C compilers. The compiler is your largest expense. Serial LCD would eliminate the need for big LCD routines like LCDOUT (free demo won't do)
    Upscale in price from JDM is the PICKIT2 It's great, but like 50 bucks. Low level 12F pics are really cheap and many have good features, but few I/O pins. Easiest PIC to start with is 16F84. Few features, several I/O s no analog features to confuse you, Pin compatable with 16F628A/648A so code will transport up. Request samples from
    Microchip, Allegro, Maxim just do not get greedy with them.
    Jun 2011
    Stockton on tees
    Thank you for all the help I have been given
    I have made a few decisions bit just need a bit more help
    I have been given a copy of flow code 3 and find It ok to use
    I think if I use it I will be ok with all the help files around the net.
    Just there are so many processors around I do not know the one to pick.
    I want a pic that will control the following
    Also the best hard wear to program it I am useing an old win98 laptop with one USB port
    1. LCD screen around 3 lines of text
    2. one stepper motor
    3. 6 inputs
    4. 6 outputs
    5. 1 Keypad
    6. 3 servos
    go for a 40 pin device then. PIC16F886, 16F877(a), PIC18F452, PIC18F4520 etc etc
    if you have a serial port, try to build your own JDM programmer, lots of info all 'round the web. Make sure the software for the JDM will support the PIC you'll choose.
    Jun 2004
    Michigan
    You could also consider the CHIPINO from chipaxe.com.
    It works with PICKit 2, PICkit 3, and any PICkit 2 clone.
    Will accept Arduino shields and is PIC16F886 based.
    They also have a breadboard version that's even cheaper.
    CHIPINO gives you the simplicity of Arduino but the power of PICBASIC or any compiler such as Flowcode.
    If you need help getting started check out rawmicro.com. They have a video on how to use Flowcode with CHIPINO.
    Chuck Hellebuyck
    Electronic Products
    http://www.elproducts.com
    [email protected]
    Jun 2011
    Stockton on tees
    Hi thanks for all the help just so many different answers I am confused. Just brought the book PIC in practice and working trough it but it's slow going and I need to get this first project finished in a month promised it to grandson for his birthday.
    Could some one please mentor me trough this first project then I can take my time with the rest of the learning
    Thank you
    Al
    Aug 2010
    Maryland, USA
    Can you answer any of my questions in post #7? You answered the whats it for part, and I agree it needs to be done in time - no dissappointing the youngens.
    Will the stepper be moving anything or just spinning with a flag on the shaft.
    -Bert
    Jun 2011
    Stockton on tees
    Forgot to answer all the questions the sevos are real servos the stepper I haven brought yet any recomendations .yes I have to do the stepper driver the out puts will fire either relays or optisilztors to protect the unit.
    Just to turn things on and off
    Hope this helped just he thinks I am like beforenand can do all this stuff but with the depression it's so hard
    Al
    Aug 2010
    Maryland, USA
    By the way I do not expect help for free I am willing to pay for your time ect
    No need for all that. Help here is free and ample!! Now thats not to say someone wouldn't be open to making it for you for a price, as long as you are doing your part like troubleshooting and trying to learn, folks here will help till its done or you stop posting.
    Now off to look at your link.
    -Bert
    Aug 2010
    Maryland, USA
    Ooh that is pretty cool!! Now not being a photographer, I have no idea what to use it for. Looks like it may be a bit much to put my cell phone camera on.
    How heavy is the payload gonna be? camera + lenses + whatever. That product says it will lift 10 pounds vertical, do you need that much?
    Not sure where the servo goes, for focus maybe?
    What are your plans for the actual slide? the easiest way to hack one would be an old printer. but you can buy the slides ready made ($$). Or if you have some tools, you can make 1 without too much trouble. The stepper size will be based on the load to move. theirs is a nema 17 size. I would reccomend a unipolor stepper. there is plenty of debate over which is better, but running at 12Vdc, I find uni better. Bi-polar is great at higher voltage and high speed. but you will have neither here. Also drives are a bit less expensive and easier to build yourself.
    -Bert
    Hi Rover999,
    Slides get very expensive, but (please do not laugh) there are a plethora of pneumatic slides available on the cheap which have very many of the exact same features as shown, just gut the cyl. for the lead screw, alternatively commercial drill rod is very hard before heat treating and machine shop suppliers also sell bearings, bushings I. E. . . Enco. . . do not forget McMaster Carr as well.
    Jun 2011
    Stockton on tees
    Hi every one is helpful I will answer Berts question first as to what it is used for it is for macro photography so when you get very close to an object only a tiny area is in focus this device takes a picture then moves a very small distance then repeats it up to a hundred times after this you use soft wear to put all the images together to get one that has lots of detail. Yes a camera with bellows and lens will be around 10 pounds.
    Tools wise I have a hand drill and some hand tools.
    If some one could make one fast for me I would be so great full just looked at my effot and it looks so poor but things are so hard at the moment for me and I do not want to disappoint him.
    I can raise around £100 just is that enough you think just time is running out and if I get taken back in hospital.
    Al
    Mar 2009
    If I was really strapped for cash, I'd approach it like this...
    Use Mach3 - their free demo will be sufficient & it already has a nice interface (saves having to write the code from scratch in picbasic)....it also has options to 'trigger' stuff (cooling fluid etc) which could be brought into play to trigger your camera/flash etc)
    GCode is easy enough to program yourself (which is what MAch3 requires)
    For the slide itself....well bearing in mind cost is significant factor, I'd be inclined to build it with bog standard M10 threaded rod - since you're only going in one direction, then backlash shouldn't be an issue.
    If you can lay your hands on some old dot matrix printers (boot fairs, s/h shops etc), they'll likely have some 13mm hardened rod & some basic method of running stuff along these rods (ie the carriage assembly), not to mention stepper motor and switches. In fact you could probably use the whole carriage assembly itself...which in one master stroke saves a massive amount of work as to how to get the carriage running smoothly & square.
    You only need a one axis driver ...perhaps use something like a dedicated stepper driver chip (eg an allegro) or there's a few basic one axis driver schematic/layouts on the net.
    I reckon this could be done for about £50....but a lot of your own time!
