PBP Support for 12F1840 8-Pin Device?
Results 1 to 18 of 18
    Feb 2010
    Default Re: PBP Support for 12F1840 8-Pin Device?
    Would it be too much if i ask you to attach the modified .inc file ?
    Thank You in any case !
    Apr 2011
    LakisFM1 - I will try to attach the one I used, along with a very short example program. Hope you find it useful.
    Feb 2010
    Thank you!
    I thought the differences in the .inc were also about the registers ,
    so i had to verify that aaaaaall the registers of the 12F1840 are in same addresses as the 16F1828.
    Or maybe is it you are using a simple TRISA/PORTA? (em, with also ANSELA,WPUA and OSCON )
    Apr 2011
    LakisFM1 - Yes, I was only doing very simple things with the 12F1840 and PBP2.6. I really just did Port toggle control and some simple PWM. All my programs were very short, mostly used to check out my handmade test board with a real 12F1840. You have my .inc and simple program, and I didn't do much more than that until PBP3 came out.
    If you are serious about using PBP with the 12F1840, then I think PBP3 is a must for you. It will make your life a lot easier. No matter what you do, the 16F1828 is not a 12F1840.
    Sorry I don't have more for you.
    Dec 2010
    So did we ever get an update to support this device in PBP 2.6?
    Quote Originally Posted by Charlie View Post
    PBP is now @ v 3.06 ...
    see here : http://pbp3.com/downloadtrial
    Dec 2010
    Thanks Alain, but the price is a bit out of my range to simply support a single new device.
    I'm not asking for more development on 2.6, I'm asking if it was ever done.
