Manometer project continued.
Results 1 to 13 of 13
    Apr 2011
    NSW, Australia
    Default Re: Manometer project continued.
    Hit the end button before finished.
    Results
    DEC 1
    47.6 Knots   686
    46.8 Knots   9598
    46.7 Knots   8727
    46.2 Knots   9162
    47.6 Knots   686
    46.4 Knots   8074
    46.2 Knots   9162
    46.7 Knots   8727
    46.2 Knots   9162
    46.8 Knots   9598
    DEC 2
    46.28 Knots   5028
    46.69 Knots   3069
    46.28 Knots   5028
    46.81 Knots   5681
    46.93 Knots   893
    46.39 Knots   7639
    46.62 Knots   9162
    46.16 Knots   6116
    46.81 Knots   5681
    46.04 Knots   7204
    DIG 1
    43.1 Knots   3910
    42.4 Knots   6946
    43.7 Knots   3475
    43.8 Knots   6086
    44.3 Knots   438
    43.6 Knots   4563
    43.5 Knots   5651
    43.5 Knots   5651
    43.8 Knots   6086
    43.8 Knots   6086
    DIG 2
    49.0 Knots   7016
    49.5 Knots   8539
    49.0 Knots   5058
    49.9 Knots   8975
    50.4 Knots   498
    50.4 Knots   498
    49.0 Knots   5058
    49.4 Knots   7451
    49.6 Knots   4622
    49.0 Knots   5058
    The value before Knots is what is the result of whether I have used DEC 1or 2 and DIG 1 or 2. The value fi=ollowing is the knotsRem variable.
    The DEC1 and 2 seem to make sense, although not displaying the first digit but the DIG 1 and 2 look to return the 2nd digit for DIG1 and 3rd digit for DIG2
    Before I was confused - now I'm way past that!!
    Looking at the manual there doesn't seem to be anywhere that left justifies a number.
    aajgss
        NUM VAR WORD
        NUM = 12345
        NUM_DIG VAR BYTE
        BOOT:
        SEROUT2 TX,BAUD,[$d,$a]
        'RETURNS 12345
        SEROUT2 TX,BAUD,["NUM= ",DEC NUM,$d ,$a]
        'RETURNS 345
        SEROUT2 TX,BAUD,["NUM= ",DEC3 NUM,$d ,$a]
        NUM_DIG = NUM DIG 4 'RETURNS 1
        SEROUT2 TX,BAUD,["NUM_DIG4= ",DEC NUM_DIG,$d ,$a]
        NUM_DIG = NUM DIG 3 'RETURNS 2
        SEROUT2 TX,BAUD,["NUM_DIG3= ",DEC NUM_DIG,$d ,$a]
        NUM_DIG = NUM DIG 2 'RETURNS 3
        SEROUT2 TX,BAUD,["NUM_DIG2= ",DEC NUM_DIG,$d ,$a]
        GOTO BOOT
    Apr 2011
    NSW, Australia
    Hi Dave,
    I think I understand where your heading with this.
    Where I can see a problem with what I am doing is I dont have a constant number of digits in the remainder. It could be 1,2,3 or 4 characters long, So DIG2 would pick the right number if the remainder was in the hundreds, but the wrong number if the result was in the thousands.
    If I remember back to Q Basic days there was a Left$ or Right$ and number of characters command, but I cant see anything like that in PBP.
    Am I seeing this right or not?
    aajgss
    Nope...
    Try something like this.
    IF NUM_REM >= 9999 and <= 1000 THEN
    DIG3 NUM_REM
    IF NUM_REM >= 999 and <= 100 THEN
    DIG2 NUM_REM
    Apr 2011
    NSW, Australia
    Ah Yes,
    A good solution, thanks. Using that method I could also now look at the second digit and if >= 5 round up to the next value.
    aajgss
