PicBasic Pro code to drive MCP4291 DAC?
Results 1 to 18 of 18
Threaded View
  1. #8
    Default Re: PicBasic Pro code to drive MCP4291 DAC?
    Okay I hammered out a routine to use the MSSP module. It gave me
    a 6x speed increase over shiftout. I'm just a hack so there maybe a
    better way to do it.
    Results:
    Shiftout MSSP
    10mhz 10hz 66hz
    20mhz 21hz 117hz
    40mhz 42hz 2 63hz
    80mhz 83hz 526hz
    The 80mhz is 20mhz crystal 4xpll, overclocking probably not reliable? but worked!
    '*  Name    : DAC_12BIT_MSSP                                    *
    '*  Author  : MARK S                                            *
    '*  Date    : 6/9/2011
    '* SINE WAVE GENERATOR USING MCP4921 12BIT DAC                  *
    '* USES MSSP MODULE vs SHIFTOUT                                 *
    '* PIC18F4680, PBP2.6 MPASM                                     *
    DEFINE  OSC 20
    'REGISTER SET
    INTCON = %00000000
    INTCON2.7 = 0       'weak pullups portB
    ADCON1 =%00001111   'ALL DIGITAL
    CMCON  =%00000111   'COMP OFF
    T3CON = 0
    CCP1CON = 0 'ECCP OFF
    ECCP1AS = 0
    ECCP1DEL = 0
    SSPSTAT = %00000000   'TX IDLE LOW,SAMPLE MIDDLE
    SSPCON1 = %00100000 ' ENABLE MSSP,CLK IDLE LOW,FOSC/4
    'PORTS
     TRISA = %00000000  ' PORTA ALL OUTPUT        '
     TRISB = %00000000  ' PORTB
     PORTB = %00000000  ' CLEAR PORTB
     TRISC = %00000000  ' PortC
     TRISD = %00000000
        TRISE = %00000000
    'DAC CONNECTIONS
    'VREF     PIN6 MCP4921 TIED TO +5V
    'CLOCK    PIN3 MCP4921 TO PORTC.3  "SCK"
    'DATA     PIN4 MCP4921 TO PORTC.5  "SDO"
    'CS       PIN2 MCP4921 TO PORTD.2
    'LOAD     PIN5 MCP4921 TO PORTD.3   CONNECT THIS TO GROUND TO SAVE A PORT PIN
    'VARIABLES
    CS_DAC      VAR PORTD.2
    LOAD_DAC    VAR PORTD.3    'KEEP LOW
    WAVE_INDEX  VAR WORD
    DAC_OUT     VAR WORD
    DAC_OUT1    VAR WORD
    SSPIF       VAR PIR1.3     ' SPI interrupt flag
    'START
    SSPBUF = 0          ' CLEAR SPI BUFFER
    SSPIF = 0           ' CLEAR SPI INTERUPT FLAG.
    LOW LOAD_DAC
    MAIN:
    HIGH CS_DAC
    FOR WAVE_INDEX = 0 TO 255
    GOSUB SINE_TABLE
        LOW CS_DAC
          DAC_OUT1 =$3000 | DAC_OUT   ' Combine table value with dac reg control
                SSPBUF = DAC_OUT1.HIGHBYTE  'SEND HIGH
                While SSPIF = 0            ' WAIT FOR TX TO COMPLETE
                    Wend
                    SSPIF = 0               'RESET INT FLAG
                SSPBUF = DAC_OUT1.LOWBYTE   'SEND LOW
                    Wend
        HIGH CS_DAC
    NEXT WAVE_INDEX
    GOTO MAIN
    SINE_TABLE:
    lookup2 WAVE_INDEX, [0,1,2,6,10,15,22,30,39,50,61,74,88,103,120,137,156,_
            176, 197,219,242,266,291,318,345,374,403,433,465,497,_
            531,565,600,636,673,710,749,788,828,869,910,952,995,_
            1039,1083,1127,1172,1218,1264,1311,1358,1406,1453,1502,1550,1599,_
            1648,1698,1747,1797,1847,1897,1948,1998,2048,2098,2148,2199,2249,_
            2299,2349,2398,2448,2497,2546,2594,2643,2690,2738,2785,2832,2878,_
            2924,2969,3013,3057,3101,3144,3186,3227,3268,3308,3347,3386,3423,_
            3460,3496,3531,3565,3599,3631,3663,3693,3722,3751,3778,3805,3830,_
            3854,3877,3899,3920,3940,3959,3976,3993,4008,4022,4035,4046,4057,_
            4066,4074,4081,4086,4090,4094,4095,4095,4095,4094,4090,4086,4081,_
            4074,4066,4057,4046,4035,4022,4008,3993,3976,3959,3940,3920,3899,_
            3877,3854,3830,3805,3778,3751,3722,3693,3663,3631,3599,3565,3531,_
            3496,3460,3423,3386,3347,3308,3268,3227,3186,3144,3101,3057,3013,_
            2969,2924,2878,2832,2785,2738,2690,2643,2594,2546,2497,2448,2398,_
            2349,2299,2249,2199,2148,2098,2048,1998,1948,1897,1847,1797,1747,_
            1698,1648,1599,1550,1502,1453,1406,1358,1311,1264,1218,1172,1127,_
            1083,1039,995,952,910,869,828,788,749,710,673,636,600,_
            565,531,497,465,433,403,374,345,318,291,266,242,219,_
            197,176,156,137,120,103,88,74,61,50,39,30,22,15,10,6,_
            2,1],DAC_OUT
