2 bytes to word array variable - fastest way
Results 1 to 16 of 16
    Feb 2011
    Michigan, USA
    Default Re: 2 bytes to word array variable - fastest way
    Well it turns out the more intuitive way is also a little faster. That is if I
    have done this correctly.
    I used [view] [program memory] in MPLab and counted the number of
    instructions between the start and end labels.
    This code was 18 lines:
    StartTest:
      adcData.lowbyte[Index] = ADRESL
      adcData.lowbyte[Index+1] = ADRESH
    EndTest:
    This code was 16 lines:
    StartTest:
      tempWord.highbyte = ADRESH
      tempWord.lowbyte = ADRESL
      adcdata[index] = tempword
    EndTest:
    So as long as I can afford the extra word variable, I will be using the
    temp variable way...... unless someone else reveals a clever trick.
    thanks all for your replies,
    Mike -
    If ADRESH & ADRESL are consecutive SFR... then you could use
        @ADRESULT = ADRESL
        ADRESULT VAR WORD EXT
        MyArray VAR WORD [8]
    Start:
        MyArray[0] = ADRESULT
    But I doubt ADRESL/ADRESH are consecutive in many PIC.
    Feb 2011
    Michigan, USA
    mister_e,
    Thats a good trick. One to remember. And it only produces 9 lines of
    instruction. But your right, the PIC I'm using (16F684), ADRESH/L are not
    next to each other.
    Actually, ACCON0 is after ADRESH. That would give you an interesting result.
    thanks,
    Mike -
