2 bytes to word array variable - fastest way
Results 1 to 16 of 16
    Default Re: 2 bytes to word array variable - fastest way
    Yes, you're quite right, otherwise it'll be as in the first example where the indexing is actually word based and we'll get the low byte of all the words instead of the low and high byte. Thanks for pointing that out!
    I wish I could edit my post and correct that but the 10 second window for doing that has passed.... :-(
    Aug 2010
    Maryland, USA
    Again thank you Henrik. Yes knowing what goes on under the hood does make it make sense, But I stand by my statement that this is a shortcomming of PBP. I would almost go so far to call this a work around for word array indexing on a byte level. I think I will add a wish list thread for this. PBP should certainly be able to distinguish the intention. It would be even more intuitive to address it this way:
    adcdata[index].lowbyte
    adcdata[index].highbyte
    But knowing is half the battle, again thanks for the very clear explanation.
    -Bert
    I fully agree, it might be somewhat logical when one understands it but it's certanly not intuitive, your format would be much cleaner for its typical purpose. I'm sure though that there are some clever tricks that can be done (which I'm not clever enough to figure out) with the way it currently is.
