DELL PC Power Problem
Results 1 to 9 of 9
    Jul 2005
    Palmdale, CA
    Default Re: DELL PC Power Problem
    I've done all of that. The supplies are all within spec with the configured load applied. What I was curious to find out what the interface circuitry on the mother board is between the "power" switch and the actual PS-ON signal that turns on the power supply. Does it come from a CPU I/O line or some peripheral glue logic? Is there a source of board schematics anywhere on the web that you know of?
    Ed
    not that I know, sorry.
    Oct 2009
    Utah, USA
    You should at least go to support.dell.com and enter your "express service code" or your "service tag" number and you should be able to get to very detailed teardown and re-assembly instructions. I used to be a Dell service tech contractor (module swapper, really) and taking apart a lap top is no small task. (at least if you want to put it back together again
    I have not been to their website in quite a while... so if you can't find the teardown instructions let me know and I'll see if I can get you a better link.
    I never did see any schematics there in all my time doing dell support.
    good luck
    Dwight
    Jul 2005
    Palmdale, CA
    Thanks for the suggestions. I was looking for information that apparently is not available to the public. I decided to bail and but a new machine. The old one was pretty old... I got an XPS8300 with the I7 processor (yes I checked the mfg date to be sure it was after Intels fix).
    Thanks again
    Ed
    Sometime it just don't worth to spend too much time on old computers. I sat: Smart move!
