Modifier error?
Results 1 to 3 of 3
Thread: Modifier error?
    Sep 2009
    Default Modifier error?
    When I try to access bits from the second byte in a array, strange things happen.
    SEROUT2 tx,mode,[bin8 NDDate[0],13,bin8 NDDate[1],13,#NDDate.BIT7[1],#NDDate.BIT6[1],#NDDate.BIT5[1],#NDDate.BIT4[1]]
    As a result I get this
    0 0 1 1 0 0 1 0 (0D)
    0 0 0 1 0 1 0 1 (0D)
    1 0 0 1
    If i try to access to first byte
    SEROUT2 tx,mode,[bin8 NDDate[0],13,bin8 NDDate[1],13,#NDDate.BIT7[0],#NDDate.BIT6[0],#NDDate.BIT5[0],#NDDate.BIT4[0]]
    Results:
    0 0 1 1
    It seems everything is OK. So what causing this error?
    I'm using pbp 2.60C, PIC18F452
    Default Re: Modifier error?
    If NDDate is the byte array you access the 7th bit of the first byte (NDDate[0]) thru NDDate.0[7] and the 7th byte of the second byte thru NDDate.0[15].
    Please see Melanies excelent writeup on the subject for further details.
    (Where's Melaine by the way, haven't "seen" her around for ages?)
    Sep 2009
    Thanks. Seems to be something I did not understand so well...
