Led limiting resistor
Results 1 to 25 of 25
    Jun 2011
    Default Re: Led limiting resistor
    Thank you Demon,
    I am testing now a ACS712 and in the scope it looks like a sine wave - 60 HZ, swinging between +1 volts to + 3.5 volts
    I will get tomorrow an LTC1966 from Linear Technology , which is an RMS to DC converter and start working from there
    Ion
    Mar 2009
    Quote Originally Posted by igeorge View Post
    Thank you Demon,
    Ion
    a liitle more meat on how you anticipate handling the 'trapping' of an element going open cicuit might be useful..... ie the whole signal chain, because I'm left wondering why you're using an RMS to dc converter (and a comparator) for a simple task that a pic can readily do for you.
    Jun 2011
    The pic is supposed to monitor 16 heaters. Can be done with a multiplexer, but my boss wants a visual LED for each burned heater, so in this case i decided to have 16 separated inputs. He wants the leds to represent the status of the inputs. He does not believe in multiplexing .... and he sign my check also
    Mar 2009
    No, that bit is clear...what I'm getting at is how are you going to have the PIC 'monitor' (ie what's the PIC gonna be looking for ....a DC level? - therefore ADC, comparator, a small AC signal? therefore ADC to extract a non zero level)....you mentioned comparators....you mentioned RMS to DC converters .....a bit more clarity on your anticipated approach at the PIC itself will help everyone help you towards your end goal.
    Jun 2011
    Some how i have to bring to pic a level 1 for each good heater and zero for a burned one. They are not enough A/D on the pic to handle 16 channels.
    So, what i need is to convert before pic the signal in zero and one . Zero for any current lees than one amp and one for anything above that
    Mar 2009
    Well, in your shoes, I'd be inclined to use two PICs and just step through the ADC channels to pick out out a 'non AC' signal (ie a dead element), else you're looking at a fair bit of 'gumph' just to put in between your 16 'monitored' signals & the PIC. (ok, so I know your boss said no multiplexing....but would he know that the ADC pins are multiplexed internally anyway?!!)
    Also you make no mention of how quick you need to be alerted....is there a 'failed heater response unit' on hot standby looking at the leds, is a minute or two ok, must this be notified within a second etc.....such requirements all help steer the final deployed solution.
    Jun 2011
    1-2 seconds will be fine
