Led limiting resistor
Results 1 to 25 of 25
    Default Re: Led limiting resistor
    I would start here:
    http://www.centralsemi.com/PDFs/sele...t_is_a_cld.pdf
    A Current Limiting Diode, also known as a “Current
    Regulating Diode” or a “Constant Current Diode”, performs
    quite a unique function. Similar to a zener diode,
    which regulates voltage at a particular current, the CLD
    limits or regulates current over a wide voltage range.
    Jun 2011
    Thanks Robert, but you missed the whole point of the question. For constant current ti is not an issue as we use Ohm's law to calculate.
    The point is in this particular case that current change from 1 Amp to 5 Amps
    I will try to make a sketch and post it soon.
    Ion
    Miami, Florida USA
    Quote Originally Posted by igeorge View Post
    Ion
    Yes, posting the schematic will help, so we can have an idea of what you are talking about. Also, what optocoupler are you using?
    Anonymous
    Jun 2011
    Hello,
    I do not have any opto in mid yet, but i am flexible on what ever i can use.
    Here is a concept of what i need
    regards
    Ion
    Miami, Florida USA
    What is the purpose of R2? I don't quite understand what you are trying to do. Are you trying to measure the current in the heater? Or, are you trying to switch it on/off?
    Anonymous
    Jun 2011
    r2 is to turn on the opto.
    all i need is to sense if the heater is burned out when the switch is closed.
    I do nt measure current
    thanks
    Miami, Florida USA
    thanks
    What about using a relay to detect if the heater is burned out?
    Anonymous
