Led limiting resistor
Results 1 to 25 of 25
    Jun 2011
    Default Led limiting resistor
    Hello,
    I have a line where the current varies from 1 to 5 amps.
    I would like to insert a resistor which will turn on an optocoupler rated at 1.5 volts , 10 mA
    The issue here is that at 5 amps i need a 0.24ohms resistor , and at 1 amp i need a 1.2 ohm resistor.
    Assuming that i use the 1.2 ohms resistor, at 5 amps will generate 6 volts and fry my opto.
    I need help to solve this issue, which i do not know how to do it
    Ion
    Default Re: Led limiting resistor
    I would start here:
    http://www.centralsemi.com/PDFs/sele...t_is_a_cld.pdf
    A Current Limiting Diode, also known as a “Current
    Regulating Diode” or a “Constant Current Diode”, performs
    quite a unique function. Similar to a zener diode,
    which regulates voltage at a particular current, the CLD
    limits or regulates current over a wide voltage range.
    Jun 2011
    Thanks Robert, but you missed the whole point of the question. For constant current ti is not an issue as we use Ohm's law to calculate.
    The point is in this particular case that current change from 1 Amp to 5 Amps
    I will try to make a sketch and post it soon.
    Ion
    Miami, Florida USA
    Quote Originally Posted by igeorge View Post
    Ion
    Yes, posting the schematic will help, so we can have an idea of what you are talking about. Also, what optocoupler are you using?
    Anonymous
    Jun 2011
    Hello,
    I do not have any opto in mid yet, but i am flexible on what ever i can use.
    Here is a concept of what i need
    regards
    Ion
    Miami, Florida USA
    What is the purpose of R2? I don't quite understand what you are trying to do. Are you trying to measure the current in the heater? Or, are you trying to switch it on/off?
    Anonymous
    Jun 2011
    r2 is to turn on the opto.
    all i need is to sense if the heater is burned out when the switch is closed.
    I do nt measure current
    thanks
    Miami, Florida USA
    thanks
    What about using a relay to detect if the heater is burned out?
    Anonymous
    Mar 2009
    Hello,
    Ion
    iF you place a 450R resistor in series with the opto, that'll ensure the voltage doesn't exceed 1.5V/10mA at the opto for 5A through the element ....of course the opto will only then 'get' 300mV if the element current drops to 1A....but without knowing more about the opto blah blah
    Why not using a Current transformer?
    Jun 2011
    I think Mister_e solution it is something which i will consider, but i have to solve the conversion of 10 mv ac/60 hz to a decent DC voltage so i can use it with a comparator.
    As i said, analog it is a mystery for me.
    Ion
    I don't understand why the need for complicated design.
    Wouldn't an appropriately rated relay do the job just as well (isolate both sides), be easy to install and be able to withstand a lot more?
    Jun 2011
    I believe that the relay first will not withstand the 5 amps on the coil.
    The second issue is that voltage is chopped by the SSR and heat controller, and the relay will come to a point when it will go crazy ON-OFF-ON , and the signal to CPU will be a pulsating one.
    Thank you
    I believe that the relay first will not withstand the 5 amps on the coil. ...
    I would think that would depend on the rating of the relay.
    ...The second issue is that voltage is chopped by the SSR and heat controller, and the relay will come to a point when it will go crazy ON-OFF-ON , and the signal to CPU will be a pulsating one.
    Thank you
    That little detail might be a big problem.
    Jun 2011
    Thank you Demon,
    I am testing now a ACS712 and in the scope it looks like a sine wave - 60 HZ, swinging between +1 volts to + 3.5 volts
    I will get tomorrow an LTC1966 from Linear Technology , which is an RMS to DC converter and start working from there
    Ion
    Miami, Florida USA
    Thank you
    You can rectify the AC signal before feeding it to the relay. Add diodes and a capacitor and you are set. Like demon said, you might be making it more complicated than what it is.
    Anonymous
    Mar 2009
    Thank you Demon,
    Ion
    a liitle more meat on how you anticipate handling the 'trapping' of an element going open cicuit might be useful..... ie the whole signal chain, because I'm left wondering why you're using an RMS to dc converter (and a comparator) for a simple task that a pic can readily do for you.
    Jun 2011
    The pic is supposed to monitor 16 heaters. Can be done with a multiplexer, but my boss wants a visual LED for each burned heater, so in this case i decided to have 16 separated inputs. He wants the leds to represent the status of the inputs. He does not believe in multiplexing .... and he sign my check also
    Mar 2009
    No, that bit is clear...what I'm getting at is how are you going to have the PIC 'monitor' (ie what's the PIC gonna be looking for ....a DC level? - therefore ADC, comparator, a small AC signal? therefore ADC to extract a non zero level)....you mentioned comparators....you mentioned RMS to DC converters .....a bit more clarity on your anticipated approach at the PIC itself will help everyone help you towards your end goal.
    Jun 2011
    Some how i have to bring to pic a level 1 for each good heater and zero for a burned one. They are not enough A/D on the pic to handle 16 channels.
    So, what i need is to convert before pic the signal in zero and one . Zero for any current lees than one amp and one for anything above that
    Mar 2009
    Well, in your shoes, I'd be inclined to use two PICs and just step through the ADC channels to pick out out a 'non AC' signal (ie a dead element), else you're looking at a fair bit of 'gumph' just to put in between your 16 'monitored' signals & the PIC. (ok, so I know your boss said no multiplexing....but would he know that the ADC pins are multiplexed internally anyway?!!)
    Also you make no mention of how quick you need to be alerted....is there a 'failed heater response unit' on hot standby looking at the leds, is a minute or two ok, must this be notified within a second etc.....such requirements all help steer the final deployed solution.
    Jun 2011
    1-2 seconds will be fine
    Mar 2009
    In which case, I'd not be going dicking about with hw comparators (that said when you think about it, ADC'ing a signal and then comparing against a preset level in software is a comparator...a sw comparator), RMS to DC converters etc....just tap off some reduced AC from each element feed (obviously 5V 'peak to peak' max, but at least here when your element is only drawing 1A there'll still be 1V AC peak to peak - more than enough to work with) ...squirt the 16 tapoffs into a PIC's ADC pins (use two PICs to get around the 'not enough ADC channels' problem). Then step through each pin all sequentially, staying on each pin for long enough to ensure you capture a 'non zero' reading (note: 'zero' here being half your VCC, so for 8 bits, and a VCC of say 5V, 2.5V = 127.....so say any ADC reading less than 110 or more than 144 means there's AC present....if so move on, if not then latch a red led, then move on etc)
    Jun 2011
    Thank you very much.
    I am going now to set up a bread board and try it
    Ion
    I'm following where Hank is going, but how will you go from 110V to 5V?
    I saw mention of the ACS712 above, I'm just curious on the details of the schematics.
