I need help to detect an AC burned heater element
Results 1 to 16 of 16
    Default Re: I need help to detect an AC burned heater element
    Hello igeorge,
    Could you elaborate a bit on the conditions you want to test the device? It seems you want / need to test during the welding operation. Can you install a tiny reed switch along the power wires? Honestly I do not know if a reed will activate on an A/C load wire, a coil like a Tape Head or a guitar pickup will. If you do not need to test during operation, then a simple continuity test should work, neon lights used to work very well for that.
    Jun 2011
    Thank you Gevo for suggestion. I have to test it first because i do not know the value of magnetic field at 10 amps.
    I will update you when i get it
    Jun 2011
    Quote Originally Posted by Archangel View Post
    Hello igeorge,
    Thanks Archangel for reading my post and offer to help.
    Here are the conditions:
    I must check during the weld process, and i have to make sure that the current going through the wire is over 1 amp.
    I do not think the other solution is feasible, due to the number of wires involved.
    What i have in mind is to have a PCB for 16 heaters and bring the wire heater to it to one terminal, run a trace through some device to get the current, then get out on the next terminal and go to heater.
    Current transformers is not a solution, as they are bulky, not to many models PCB mount and i still need to interpret the reading.
    My option was for ACS712 , but if you look at the attached graph you will see that the output is + and -
    I need somehow to convert it, or do something that i will get only the + portion, but not pulsating, i need it as a continuous line.
    Also, i need that any voltage over 2.6 volts to be a logic 1 and any voltage from 0 to 2.6 to be a logic ZERO. In this case, i will have my inputs to PIC set to read 1 for a good heater, and 0 for a bad heater.
    Thank you
    Quote Originally Posted by igeorge View Post
    Thank you
    Ok so I am thinking, use 2 diodes in parallel with their polarities reversed so there is a path for both phases, then only run the forward phase through the device.
    0 amps = 2.5v 1 amp or more, is above 2.7v.
    What do you think, will this work?
    Apr 2006
    New Hampshire USA
    Hi igeorge,
    If you just need an un-calibrated “Go - No Go” measurement, a simple “peak detector” could work.
    If a silicon diode has too much junction drop, maybe a germanium or Schottky diode would work.
    Just a diode to a capacitor circuit on the output of the ACS712.
    Jun 2011
    Hello Adam,
    Thanks for reply but i am afraid, like i mentioned before about the power dissipation on the diodes.
    I have to do some tests to see if it will work.
    Ion
    Apr 2006
    New Hampshire USA
    Hi Ion,
    You are right to be concerned with the several watts per diode dissipation with diodes passing Amperage..
    But I am proposing using them in the 5V output circuit of the ACS712.
    They would have almost no current. and would give your digital pin a 2.5V to 5V swing.
    If the peak Voltage was a little too high for your logic levels then add a “Voltage divider (= two resistors).
    -Adam-
    Maybe a simple diode bridge with a optocoupler can give a low cost solution.
    Put the ac pins of the bridge in series with the element. Short the dc pins together.
    Put an optocoupler with a small series resistor in parallel to the ac pins of the bridge. Use a small integration of the pulses of the output optocoupler.
    You are done!
    Jun 2011
    Thanks Archangel,
    I do not know if it will works, but i will try it. I am some how concerned about the power dissipation as they are 5 amps going through the diodes, and they will be 32 on one PCB for 16 heaters. I will test and let you know.
    Thanks again
    Ion
