I am not sure what you are asking. Do you mean when you receive first byte and it's 9, then the second byte is D, you want to put these together as 1 byte 9D?
To do that try this:
Now if this is not the question, can you please explain more?Code:byte1 var byte Byte2 var byte Result var byte Byte 1=byte 1<<4 ' shift low nibble to high nibble Result =byte1 + byte2
