USART control question
Results 1 to 3 of 3
    Question USART control question
    hi friends, i have a problem. i'm trying to control a motor using USART interrupt. my program is like this;
    (after definings...)
    START:
    IF DATA="A" THEN
    MOTOR1=1
    MOTOR2=0 'motor1 and motor2 are the control
    'terminals of L298n motor driver
    DATA=0
    IF DATA="B" THEN
    MOTOR1=0
    MOTOR2=1
    DATA=0
    GOTO START
    DISABLE
    INT: 'this is the interrupt program
    GIE=0
    hSerIn , [WAIT ("1MR"),RX]
    DATA=RX
    TEMP=RCREG
    RCIF=0
    GIE=1
    RESUME
    ENABLE
    With this program my motor runs for one or two seconds after that the motor stops itself. Do you have any idea what the problem is?
    Default Re: USART control question
    i have found that DATA = 0 is the problem i hope this helps anyone who has this problem.
    Aug 2008
    Portugal
    Quote Originally Posted by sburakguneri View Post
    You cannot use the word "Data". DATA is a command to store constants in on-chip non-volatile EEPROM. YOu can see that in the PBP Manual!
    Thanks and Regards;
    Gadelhas
