Weird problem with logic level on pin.
Results 1 to 13 of 13
    Default Re: Weird problem with logic level on pin.
    Aahrgh, sorry can't read my own code...The input pin in question is PortB.3 not PortA.0, sorry about that - and it IS set to an input.
    No, the 18F2431 doesn't have any comparators and all pins are set to digital with ANSEL0 = 0.
    Here's what the hardware looks like (again, that should read PortB.3, not A.0):
    As I've said, the hardware has been this way "for ever" and it has been working just fine "for ever". I changed the code and all of a sudden it didn't see the input. I could go back and forth between working and not working by basically changing where in the code I polled the input.
    Again, the voltage at the pin WAS indeed outside the electrical specs but I still don't understand how it can see the input in one version of the code and not the other. The diode in series with the opto-isolator is NOW a shotky type and it's back up and running with the new code. I'm still looking for an explanation though.
    Does the code modification also add/modify what happen to the adjacent "offending" input pins?!?
    Or you've been lucky OR...well... let's apply this rule
    Sometimes, you don't wanna know why... and stay happy
    Keep it simple... Look forward
    Have you looked at the transitions with a scope?
    Is there any undershoot?
    The non-filtered version would be more likely to catch short lived pulses just under the threshold.
    No I have not scoped it but it's got to be something like that. I'm just a bit surprised that it "never" (that I know of) missed it before and now it didn't see it at all. I spent quite some time staring at the code before I even bothered to put the meter on it since I "was sure" that the hardware was OK.
    I'll scope it next time I work on that project.
    Thanks!
