Weird problem with logic level on pin.
Results 1 to 13 of 13
    Default Re: Weird problem with logic level on pin.
    Probably not...
    But what if the flow is changed a bit?
        IF RunServo = 1 THEN  CONTINUE
        CONTINUE:
        IF FaultInput = 0 THEN
        Accumumlator = Accumulator + 1
            IF Accumulator = Limit THEN
            FaultFlag = 1
            GOSUB Abort
            'ENDIF
            Accumulator = 0
        IF FaultFlag = 0 THEN GOSUB DoServo
        GOTO Main
    Thanks Dave, I see now that I made a terrible mistake when typing in the example, the Accumulator gets reset when RunServo is 0 and not when FaultInput is 1, this is of course wrong. That, however, is not the case in my real system. Here's the exact code, cut and pasted from my program:
    If ServoFault = 1 then Goto OverRunPID          'General fault flag set - don't run servo loop.
    If RunPID then                                  'Time to run the servo-loop?
    '----------------------------- Added 2011-06-03 -----------------------------------
        If ip_Fault_Input = 0 THEN                                  'External fault input is "active"
            FaultFilterAccumulator = FaultFilterAccumulator + 1     'If so we increment the accumulator for the filter
                If FaultFilterAccumulator = FaultFilterConstant THEN  'Have we reached the filter limit?
                    ExternalFault = 1                                 'Set the FAULT Flag
                    BlinkPattern = Pattern_Ext_Fault                  'Change the pattern for the status LED
                    GOSUB AbortServo                                  'Abort the servo loop.
            FaultFilterAccumulator = 0
     op_LED = 1                                    'Drive LED on the module.
     GOSUB DoServo                                  'Rune the servo loop
     RunPid = 0                                     'Clear flag
     op_LED = 0                                    'Turn off LED on the module.
    OverRunPid:
    This works fine now that I've changed the diode so the voltage at the pin is within specs. If I change it back to the 1N4148 it does not work, the input is not seen. But WHY does it see it before, when the checking of the input was outside the IF RunPID THEN construct? Here's how it looked before which has worked fine for years:
        ExternalFault = 1                           'Set software flag indicating fault
        BlinkPattern = Pattern_Ext_Fault            'Select the "blink pattern" for the FW-LED
        GOSUB AbortServo                            'Abort servo operation.
     PortA.0 = 1                                    'Drive LED on the module.
     PortA.0 = 0                                    'Turn off LED on the module.
    OverRunPID:
    If I run this version, with the original diode in place it works just fine and both versions above works now that the voltage level on the pin is within specs. But why does one work and not the other when the voltage is slightly out of spec? I wouldn't be surprised if neither worked but the original code have worked, with the original hardware, "for years".
    The only thing I can think of is that previously the input could get checked tens of thousand of times per second depending on what else was done thru the main loop. Perhaps some capacitive coupling or whatever made the voltage go down to within specs for a short time making the PIC pick it up. But now, when it's "only" checked 1500 times per second that isn't working any more....I don't know...
    Depending upon which port you are using . . . some Schmidt trigger inputs there.
    ...Never mind.....
    As the code shows I'm using PortA.0. Schmidt trigger or not why would that make a difference in this case, care to elaborate a bit? Same pin, same signal, same voltage on input. One program sees the input it, the other doesn't.
    I'm still pretty much stumped on this one.
    By any chance... is there still any ADC or Comparator enabled on those specific pins...
    Aahrgh, sorry can't read my own code...The input pin in question is PortB.3 not PortA.0, sorry about that - and it IS set to an input.
    No, the 18F2431 doesn't have any comparators and all pins are set to digital with ANSEL0 = 0.
    Here's what the hardware looks like (again, that should read PortB.3, not A.0):
    As I've said, the hardware has been this way "for ever" and it has been working just fine "for ever". I changed the code and all of a sudden it didn't see the input. I could go back and forth between working and not working by basically changing where in the code I polled the input.
    Again, the voltage at the pin WAS indeed outside the electrical specs but I still don't understand how it can see the input in one version of the code and not the other. The diode in series with the opto-isolator is NOW a shotky type and it's back up and running with the new code. I'm still looking for an explanation though.
    Does the code modification also add/modify what happen to the adjacent "offending" input pins?!?
    Or you've been lucky OR...well... let's apply this rule
    Sometimes, you don't wanna know why... and stay happy
    Keep it simple... Look forward
    Have you looked at the transitions with a scope?
    Is there any undershoot?
    The non-filtered version would be more likely to catch short lived pulses just under the threshold.
    Hello Henrik,
    Here is my thoughts, for better or worse . . . Schmidt Trigger is more particular as to threshold voltage as to when it switches, both high and low. TTL switches around 1/2 way between VSS - VDD, if your diodes are different in terms of their switching voltage, as I see it, 1 will work and the other will not, and your VOM might not be high enough impedance to see the difference.
    In any event, as I said, those are my thoughts . . .
    Yes, but I didn't switch inputs or diodes or did anything else to the hardware. It was working just fine with the old code but stopped working with the new code. I took a working board and downloaded the revised code. Nothing changed hardware wise, just the code. Reverted to the old version - everything OK. New code, nope.
    It's got to be something in line with Darell's thinking. Previously it checked the input in a very tight loop except when it ran the servo loop which is around 350us 1500 times per second. Now it checks it a single time each time it enters the servo loop.
    But if this is the case I would expect it to have missed it on ocations even with the old code. After all, it's busy ~50% of the time thus not checking the input so if an undershoot event on the signal was what caused it to work I must have been seriosult lucky since I haven't had it miss a single time.
    Thanks!
