Problem getting button to turn on LED using 12F675
Results 1 to 9 of 9
    Default Re: Problem getting button to turn on LED using 12F675
    Quote Originally Posted by Jeff View Post
    Thanks guys, you were both right; rookie mistake on my part. It works now - onward and upward. Now the button turns on LED2 and off LED1. SWEET!
    Welcome back Jeff,
    3 years almost. I think what trips up people is this statement,
    CMCON = $?? 'MAKE PINS DIGITAL
    Which seems to reappear on a regular basis, perhaps copy paste, it should more factually report,
    CMCON = $?? 'Disable input Comparators
    The ANSEL is the 'MAKE PINS DIGITAL part of the equation, as you found out, My post here is for the future newbies who read this post.
    Jun 2008
    Spokane, WA
    Smile Re: Problem getting button to turn on LED using 12F675
    Quote Originally Posted by Archangel View Post
    Welcome back Jeff,
    3 years...yes, i probably gave up for 3 years because of this. Also, i was using picbasic, not pro. Pro is SOOOOO much easier. it is worth the lute. I was struggling with the stupid button command for a couple weeks and gave up. Then i read Chuck Hellebuyck's book; "Programming PI uC's with picbasic" and he mentioned a workaround by directly addressing memory. I am finally starting to 'get it'. Thanks.
    Glad to see you back, You are right, PBP IS worth the extra money.
    I think the Button command is overly complicated vs 2 ifs, but maybe it saves codespace? Anyway keep on coding, the forum is here when you need it.
