Forgot how to do this
Results 1 to 3 of 3
    Aug 2009
    Paso Robles California
    Default Forgot how to do this
    I have forgotten how to get multiple bytes using the I.0{x} to increment
    its been a while and my notes are not as clear as I thought, or my mind is a little foggy and my notes are great.
    POSISTION VAR BYTE(3) or posistion.0{I}
    I VAR BYTE
    FOR I = 1 TO 3
    SERIN2 PORTA.1,84,[POSISTION.0{I}] 'NEED TO GET POSISTION INFO
    SEROUT2 PORTA.0,84,[POSISTION.0{I}] 'SEND BACK TO ECHO TO CONTROLLER
    NEXT
    Larry
    Default Re: Forgot how to do this
    Hi Larry,
    To access the individual bytes in an array you do:
    Position VAR BYTE [3]
    For i = 0 to 2
       SERIN PORTA.1, 84, [POSITION[i]]
       SEROUT PORTA.0, 84, [POSITION[i]]
    Next
    Note that the array is zero-indexed, first byte is Position[0], last byte is Position[2].
    The Position.0[i] thing you have in your notes is used when you want to access the individual bits in something not specifically declared as an array an of bits. For example Position.0[8] will access the least significant bit Position[1].
    Hope that makes sense.
    Aug 2009
    Thanks Henrik ?
    this look like what I want, and yes my notes say bits but I skipped over that word (of course).
    Thank you
    Larry
