PIC16F777 - setup
Results 1 to 7 of 7
    Mar 2011
    cape town, south africa
    Default PIC16F777 - setup
    Hi All,
    I hope someone can end these hours of frustration. I try very hard to find relevant threads before adding my problems to the list, but I am at a loss;
    I'm trying to use a PIC16F777, with three HPWM and all other pins set to digital I/O's.
    It's the config registers that get me - I've read the datasheet, but just don't understand how to translate that to PBP!
    Thanks!
    Default Re: PIC16F777 - setup
    I think it's more about CCP register than config fuses.
    Sure enough, there's code example in here showing how to use the three channels.
    Mar 2011
    Thanks Darrel,
    I have been through this - but it's still not clear to me;
    The files in my assembler's folder are *.epc, so not exactly what is discussed in the post you have forwarded. For instance, in my PIC16F777 file is the following;
    ConfigLoc=0
    ConfigBase=0x3fff
    ConfigMask=0x31ff
    GroupName="Oscillator"
    GroupMask=0x0013
    ItemName="EXTRC ClockOut"
    ItemValue=0x0013
    ItemName="EXTRC"
    ItemValue=0x0012
    ItemName="INTRC ClockOut"
    ItemValue=0x0011
    ItemName="INTRC"
    ItemValue=0x0010
    ItemName="EC"
    ItemValue=0x0003
    ItemName="HS"
    ItemValue=0x0002
    ItemName="XT"
    ItemValue=0x0001
    ItemName="LP"
    ItemValue=0x0000
    I assume the "group mask" is the setting used if not otherwise defined. I do not understand how to change these in the @ define statement. Thanks for your help!
    The .epc files are part of the melabs programmer folder.
    Those are for the epic, U2 and field programmers only, they have nothing to do with your PicBasic Pro program.
    The assembler is in
    c:\program files\microchip\mpasm suite - 32-bit systems
    c:\program files (x86)\microchip\mpasm suite - 64-bit systems
    Mar 2011
    Indeed!
    Many many thanks guys!
